LT77 & LT230 from 200TDI - Defender Source
Old July 8th, 2009, 11:24 AM
ajh
Andrew J. Hutton
1993 Defender 110 200TDI
I have removed the LT77 from my 1992 200TDI defender and it is now for sale. There was some minor damage to the bellhousing cause by Frogs Island 4x4 leaving the head of a sheared bolt inside when they replaced the input shaft last year (by the way did I mention it has a nearly brand new input shaft? ) but it is all good now and ready to fit. Short bellhousing so it should fit most Series or 200TDI I believe.
I also have the LT230 transfer case along with it. I am open to reasonable offers.
Old July 8th, 2009, 12:38 PM
serial numbers of both boxes and a report or photo regarding lt230 input gear spline wear would be helpful in determining a price to offer.
Old July 8th, 2009, 01:06 PM
ajh
Andrew J. Hutton
OK, will grab those this afternoon. The input shaft was replaced very recently, a couple months before I bought it in Nov I think and I only drove it from Halifax back to Ottawa before tearing things down so it is perfect.
Old July 8th, 2009, 01:30 PM
andrew
thanks, I meant the input gear spline in the transfer box. these wear in conjunction with the spline on the tailshaft of the transmission, due to lack of lubrication. later ones had a cross drilled input gear to provide better oiling. the interim fix was an oil feed plate located right behind the rear pto cover.
Old July 8th, 2009, 04:45 PM
oilburner's Avatar
oilburner
JL
large pile of parts
Andrew - If you aren't sure you can pull the T case input gear out through the PTO cover to inspect.
Old July 23rd, 2009, 01:44 PM
ajh
Andrew J. Hutton
Serial numbers
lt230 - 22D218832D
lt77 - 50A0099555
not sure when I would ge enough time to check internals more, just wrote my todo list for the next 3 weeks and it added up to about 3 months of work
200tdi, lt230, tdi
200Tdi and LT230 Gear Ratio Question newfD90 Defender Technical Discussions 33 June 1st, 2016 02:30 PM
bolting 200Tdi to LT77 question Gkase Defender Technical Discussions 9 September 12th, 2009 12:23 AM
LT77 crapped out on 200Tdi - swap in R380 ? metric Defender Technical Discussions 8 June 11th, 2008 11:58 PM
LT77 and 1.4 high range LT230 evilfij For Sale - Parts 15 April 26th, 2007 12:06 PM
difference: Disco 200tdi and Defender 200tdi? jaherring Defender Technical Discussions 30 June 3rd, 2005 10:10 AM
