LT230 Transfer Case, 1.410 Ratio - Defender Source
Old December 16th, 2010, 02:19 AM
RyanS's Avatar
RyanS
Ryan
'93 NAS 110
This transfer case was purchased directly from Ashcroft in the UK. It's a 1.410 ratio with only about 5K miles on it. After running it briefly on my truck, I decided to go with a 1.2 TC instead. With core charge, shipping, and exchange rate, I paid about $1200. Looking for $500 plus shipping. Local (SoCal) sale preferred.
Name:	090225 LT230 001.jpg
ID:	34011   Click image for larger version
Name:	090225 LT230 002.jpg
Name:	090225 LT230 003.jpg
Old December 16th, 2010, 02:50 AM
jrose609's Avatar
jrose609
Jason Rose
1983 110 County 200tdi
Good price. Too bad you hadn't been selling about two months ago. I just picked one up from Ashcroft.
Curious, why the change back to the 1.2?
Old December 16th, 2010, 06:36 AM
The Dro
Dro
1988 Ninety
Licked pending shipping info.
Old December 16th, 2010, 01:27 PM
jrose609's Avatar
jrose609
Jason Rose
Awesome Pedro. It's a great deal.
Old December 16th, 2010, 02:24 PM
RyanS's Avatar
RyanS
Ryan
'93 NAS 110
I'm running an HS2.8 diesel, and the diesel just seems to like the 1.2 ratio much better.
Pedro - check your PM.
Old December 16th, 2010, 02:55 PM
The Dro
Dro
1988 Ninety
Replied back.
Old December 16th, 2010, 11:24 PM
dogbite's Avatar
dogbite
Paul D
95 D90 ST & SW
Seconds if Pedro backs out
Old December 17th, 2010, 12:37 AM
c.dannen
Chad Dannen
93, NAS 110, HS 2.8 TGV
Funny, I'm running a 1.21 with a HS2.8 in my D110 and I just bought an Ashcroft 1.4 for a little shorter gears, I have a 1.2 with fresh gears and bearings for sale, w/ 5K miles...
Chad
Eugene, OR
Old December 17th, 2010, 02:36 AM
RyanS's Avatar
RyanS
Ryan
'93 NAS 110
Chad - what trans are you running? I have a ZF auto, and it runs much better with the 1.2 TC.
Old December 17th, 2010, 08:25 AM
Ryan, can you describe the difference you feel between the two? I have a ZF auto in my D90 with what I believe is a 1.2 and the gearing is pretty high. I went to 4.11 gears in the diffs, but think perhaps a 1.4 transfer case would be good too.
Old December 17th, 2010, 11:34 AM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
Charles that 1.4 with your 4.11 gears will be very high. I ran that for a weekend because my transfercase went and swapped in a 1.4. Its the equivilant to running 4.75 gears. You have 33" tires right? I would think that autobox with the 4.11 would move you just fine, no?
Now I have a 1.4 with 3.54 gears which is the same as 1.2 with 4.11 gears.
Old December 17th, 2010, 11:40 AM
Yeah it's fine on the highway now (rpms were stupid low before) but I still feel like I could use a little lower ratio on the trail. It might just be the feel of the auto though.
You are probably right that the 1.4/4.11 combo would crank my rpms up too high on the highway.
Old December 17th, 2010, 05:12 PM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
I'm thinking of doing the same switch with a 300tdi manual. I was thinking it would pretty simple to just switch in a 1.2 gear kit? No?
Old December 17th, 2010, 05:18 PM
I believe so yes, but don't have any first hand knowledge
Old December 17th, 2010, 09:05 PM
This involves removing the tcase and dissasembling it. Its probably easier and cheaper to find a good used 1.2 to reinstall quickly and still have a complete 1.4 to swap back in
Old December 18th, 2010, 08:05 AM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
Too funny. I just switched from 1.2 to 1.4 in my 110 with 200tdi. My issue was the 35" tires. I still am going change the axle gear ratio as my heavy truck hates really steep hills on the trail.
Swapping t-case gears is real easy, the real PITA is getting the t-case in and out.
I have a used set of 1.2 gears if anyone wants them.
Semper Fi!
Old December 18th, 2010, 10:05 AM
gchinsr's Avatar
gchinsr
Greg Chin Sr
1996 Discovery 5 Speed
If still available, I'm in So Cal and can pick up
Tanks
Greg
Old December 19th, 2010, 02:56 AM
c.dannen
Chad Dannen
RyanS-
I am running an Ashcroft Diesel R380.
Chad
------ Follow up post added December 19th, 2010 12:29 AM ------
This is my experience with changing gears in an LT-230.
I'm not a gear box guy but I rebuilt a LT-230 in a couple weekends with some rover buddies that knew a little more than me, it was fun and a great learning experience. I installed it in my Defender and it was nice and sweet for a couple miles, then it became noisy. I did not have the correct load on the bearings. This is the seemingly simple task that can turn into a small Harvard education.
I ran the noisy t-case for several thousand miles until I did the diesel swap. I bought new 1.2 gears and bearings and had a gearbox guy build my t-case and its sweet, but the gears are too tall for me. I think I have $1000.00 in labor and a few to several hundred in parts in the rebuild. Its now is for sale.
When I decided to change to 1.4 gears, My buddy and I bought two 1.4 cases from Ashcroft, everything included at the end of the day cost $1,605.00 EACH with HD cross-pins. Same or less than rebuilding and you have an extra t-case to sell. When buying a t-case from Ashcroft, you are the importer and you must become educated with the importation process BEFORE shipping. This is very important! Ashcroft is a good gear box shop, but they are not in the business to educate you about importation.
Good luck with your gear swaps. I'd be happy to help by sharing my experience.
Chad
Old December 19th, 2010, 07:01 AM
Charles low ratio gearing is the same in 1.2,1.4, & 1.6. Only way to change that is to lower your diff ratio's or put a crawler kit in your tcase
Old December 19th, 2010, 10:41 AM
Thanks Doug - probably explains why I went to 4.11 gears in my diffs instead of trying this before. Man my memory sucks
Funny, because I didn't see your post and just googled it and found this from ECR's site (thanks ECR), and came here to get confirmation. So thanks for the response in advance!
Sorry for the hijack
Originally Posted by ECR Website
" I want the LT230 transfer case with the 1.4 ratio vs. my current 1.2 so that I can have a better low range crawl ratio."
This isn't the right thing to do to lower your crawl ratio. The stated ratio for an LT230 transfer case refers to the HIGH RANGE ONLY. The LOW RANGE gearing in a 1.4 ratio LT230 and a 1.21 LT230 are EXACTLY the same. The only difference is in the high range. 1.4 ratios were fitted to diesel D90s and Defender 110s, where the 1.2 ratio boxes were installed in USA Defender 90s and Range Rovers and Discos. To alter your low range you will need a custom low ratio kit for an LT230 like those sold by Great Basin Rovers, or your can change your ring and pinion with a 4.11 gear set or ??, but changing your LT230 will gain you nothing in low range.
lt230, transfer case
Lt230 transfer case for sale draaronr For Sale - Parts 4 April 15th, 2017 07:22 AM
LT230 Transfer Case jimmy salmon For Sale - Parts 2 December 17th, 2004 07:19 PM
1.4 ratio transfer case dave_lucas Wanted 2 November 13th, 2004 02:16 PM
Rebuilt LT230 Transfer case Bill Jansz For Sale - Parts 0 March 9th, 2004 07:00 AM
transfer case redrover Defender Technical Discussions 9 January 27th, 2004 02:41 PM
