LT230 out of 94 D90 80k $350 - Defender Source
Old November 5th, 2004, 03:52 AM
LT230 transfer case out of 94 D90 with 80k. Diff blew up. I replaced the diff with a used one.
$350
Ron
evilfij at yahoo dot com
Old November 6th, 2004, 02:56 AM
pendy's Avatar
pendy
jim pendleton
89'd90
I will trade you a plastic Disco fuel tank, a 110 driveshaft and a set of v8 motor mounts if you ship it Forward Air, on you, to Kansas City. Heck you got it from Al for free, I remember the post. Did you at least reseal it? Is the parking brake with it?
Otherwise I got this stuff for you now. And I can share pics of using a Disco tank in a 110.
JP
legend in my own mind
Old November 6th, 2004, 05:47 AM
Pendy,
$50 for the t-case from Al and $100 for another t-case with a bad bearing to get the used diff plus my time (my new job I will bill $300 an hour ). I cleaned out the inside, resealed the PTO cover, front output, rear output, no parking brake, input is 2in but is still tight on a new shaft, I did not want to update as the 3in will not go over most R380s that are in D90s. No new input seal as they vary depending on what you are putting it in.
The 110 drive shaft is worth $100 to me and the motor mounts $30, I have a tank I just need a D90 style pump. Send me an email and I will have Alyssa paypal you or send a check.
Ron
Old November 6th, 2004, 05:56 PM
pendy's Avatar
pendy
jim pendleton
89'd90
Do you have a D90 fuel tank? The D90 pump housing has a built in vent. I do not want to give you a D90 pump housing if you are using a bigger tank that has its own vent built in. Follow me?
The transfer case is worth what you are asking I just like tot get a rise out of people. Do you know of a RRC for my cousins project. Tony sold it outright and the Toyota corp. did not come through for their team.
I will check in later.
Jim Pendleton
Old November 6th, 2004, 07:58 PM
Abrooks's Avatar
Abrooks
Tony Brooks
Pendy, have found some other options for y'all, drop me a line. Tech content: I figured out today that there's no practical way to substitute a Bosch alt. out of a 3.9 disco into a marelli-equipped 90 without a LOT of work. I do know how to rebuild a doortop now though. I've also forgotten how the southdown axle guard mounts orient on the radius arm mounts. Anyone know?
TB
Old December 1st, 2004, 05:33 PM
Nil
Teague Plain
1994 Defender 90 ST
Exclamation Lt230
This xfer case still available?
R,
Nil
90, d90, lt230
Wanted: 94 D90 Transmission R380 & Transfer Case LT230 WOVOKA Wanted 1 June 11th, 2006 01:23 AM
94, AA Yellow D90 Zimbo76 For Sale - Vehicles 9 October 27th, 2004 10:39 AM
Stock 94 D90 Parts For Sale Joe B For Sale - Parts 1 January 14th, 2004 01:52 PM
looking for a Transfer Case for '94 D90 rover_rich_d90 Wanted 5 November 12th, 2003 06:46 PM
