LT-85 HD Complete - Defender Source
Old May 16th, 2015, 10:55 PM
RoverBuild
Larry
1995 RRC LWB
LT-85 HD Complete
Here is a brief history of it courtesy of the web
The LT85 (85 mm shaft spacing) was used in all V8 110 and 90 Land Rovers. The LT85 was originally designed under contract by Land Rover for Santana in Spain and was considered to be a strong working gearbox. Rover purchased LT85 gearboxes directly from Santana. It is also known as the Spanish Box. This gearbox was used as originally designed until 1988. A cost reduced, lighter weight, divided case version of the LT85 was introduced in 1988 and used through 1991. The main short coming of the divided case version was its main and lay shaft bearings. The loading on the bearings in 5th gear caused frequent gearbox failure when cruising for long periods of time under high throttle. There was also a bearing quality problem at one stage of manufacture and the gearbox was sensitive to the type of oil used.
I have the 2.5L NA bell housing with clutch and all components, and I also have the V8 Bell housing perfect for the V8 Conversion on a series! Approximate mileage is 20K.
$600
Old May 16th, 2015, 11:00 PM
mgreenspan's Avatar
mgreenspan
Matthew Greenspan
Land Rovers
How much for just the V8 bellhousing?
Complete HD Salisbury Rear Axle For Sale Northface For Sale - Parts 4 July 21st, 2006 08:29 PM
NRP COMPLETE Exhaust for '97 OBDII D90 dmarchand For Sale - Parts 9 September 30th, 2004 09:07 AM
For Sale: 3.9 Complete Joe B For Sale - Parts 1 April 20th, 2004 03:54 PM
Complete intake manifold orlandog For Sale - Parts 0 February 29th, 2004 12:43 AM
NON ABS Complete brake system Way Wanted 12 November 12th, 2003 08:47 PM
