LR3 Steel Pan Conversion Kit $50 shipped - Defender Source
Old June 15th, 2015, 08:47 PM
lordhelemt's Avatar
lordhelemt
Paul
1995 D90 #2620 & NAS 110
Steel pan conversion kit for your LR3. This is the Ford pan kit so you can use off the shelf Motocraft parts for your transmission maintenance. With this kit you will still need to remove the exhaust (I donít think youíll need to lift the engine like you do with the factory replacement). I ended up going with another kit that allows for an easier replacement. There a 1/2Ē hole in the pan for a drain valve that you will need to supply. I did attempt to install these parts so they do have ZF fluid on them but the truck was never run or topped off.
$50 shipped since they arenít technically NIB, which is ~$30 savings if you were to buy these new. All youíll need to do is add a $10 universal drain plug and you are good to go.
Pan Genuine Ford 9L3Z-7A194-A
Filter Motocraft 7L1Z-7A098-A
Gasket Fel-Pro T0S18753
ID:	122975   Click image for larger version
RIP 1994 D90 #999 (engine fire 2002). We'll miss you.
conversion, kit, lr3
Hid xenon conversion kit (full kit) East Coast Defender For Sale - Parts 15 September 19th, 2013 06:27 PM
Steel RRC Nuts $60 shipped Brewie212 For Sale - Parts 3 August 7th, 2013 08:24 PM
winch line 3/8" steel & roller fairlead ($65 shipped) nathanwind For Sale - Parts 16 March 12th, 2013 10:18 PM
Black Stainless Steel Front Grills 170.00 shipped SafariHP The Vendors Loft 2 October 11th, 2009 07:29 AM
TD5 Door Hinge Kit NTO in ROW Green 150.00 shipped SafariHP The Vendors Loft 0 October 10th, 2009 08:33 AM
