LR3 8 pin connector for the 3 Amigos - Defender Source
Old August 19th, 2015, 08:46 PM
lordhelemt's Avatar
lordhelemt
Paul
1995 D90 #2620 & NAS 110
I had a corroded connector creating the HDC/Transmission fault special programs off, etc. This is the problem that is created by a bad brake light switch, wrong bulbs, bad splice, or corroded connectors. I was able to find the proper Tyco AMP TE connectivity connector and have a few extras if anyone is in needs them.
$20 shipped conus for the following
1 each of part # 6-1419167-1 8x2 male connector
16 each of part # 2-1419158-5 male pins
1 each of part # 9-1419170-1 8x2 female connector
16 each of part # 1393366-1 female pins
i didn't feel like counting out all the pins so the pic just shows 1 each on the contacts.
RIP 1994 D90 #999 (engine fire 2002). We'll miss you.
Old August 19th, 2015, 10:28 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
Can I ask where this connector is?
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old August 19th, 2015, 10:31 PM
lordhelemt's Avatar
lordhelemt
Paul
Passenger side footwell behind the trim on the right hand side. Its the lowest connector (closet to the carpet) behind the trim piece. I'll snap a pic tomorrow.
Old August 19th, 2015, 10:37 PM
roverman2010
1985 LR 90 200Tdi
So did you fix your front sunroof drain as well?
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
Old August 19th, 2015, 10:53 PM
lordhelemt's Avatar
lordhelemt
Paul
that's next. drives side drain is broken at the elbow. pass side looks fine so will be checking for leaks at the A piller. Just need to get home while there's still daylight. May wait until this weekend to square that away.
Old August 20th, 2015, 09:48 AM
lordhelemt's Avatar
lordhelemt
Paul
Assuming the paypals come through I just have 1 connector left
Old August 20th, 2015, 12:33 PM
Ray_G's Avatar
Ray_G
Ray Gerber
Paul-
Will send mine when I go static in Abu Dhabi-gotta get out of KSA 1st! Def interested.
R-
Ray
Old August 20th, 2015, 12:35 PM
lordhelemt's Avatar
lordhelemt
Paul
Originally Posted by Ray_G View Post
Paul- Will send mine when I go static in Abu Dhabi-gotta get out of KSA 1st! Def interested. R- Ray
No worries its circled up. Whenever is fine.
Old August 20th, 2015, 09:25 PM
lordhelemt's Avatar
lordhelemt
Paul
For those that asked here is the location of the connector.
ID:	127598   Click image for larger version
lr3
Hella Euro 7 Pin to 4 Pin Trailer Wiring Adapter Wolf Fabrication For Sale - Parts 2 February 28th, 2013 02:57 PM
Connector for a 2-pin Speedo sender tomaco1 Defender Technical Discussions 16 April 30th, 2011 07:13 PM
D90 caliper brake pin - cotter pin help Gardrover Defender Technical Discussions 4 May 29th, 2009 02:01 AM
3-pin male connector for the NAS/post 1995 Defender brake light Pat Wanted 5 May 29th, 2006 10:23 PM
Trailer Light Connector loykd Defender Technical Discussions 3 November 17th, 2003 04:31 PM
