LR 4-pin diff. for D90,D1,RRC $200 shipped - Defender Source
Old September 11th, 2013, 05:15 PM
DaveC
David Crall
1996 Discovery
LR 4-pin differential center for sale. This is an excellent differential out of the rear of a 4.6 RR. It was machined to work 100% properly in D90,D1, and RRC differentials. Basically the ring gear mounting flange diameter was cut down 1/2", the webbing was cut down some, and one bearing journal moved deeper into the center by about 1/4". All of this done to match the regular long-nose differential center specs. The older LR 4-pins are hard to come by, so this is a common modification in Britain. All modification done by a good machine shop. The bearing journal modification was measured and cut by computer managed equipment to be perfect. Machine work cost $150 and the diff. cost me $200. I took the differential apart after the machine work to check for metal filings and cleaned everything. The gears and shafts were 100% perfect. I properly re-torqued the case bolts with red thread locker too. It's a very strong open diff.
Second picture shows the 4-pin on the right.
New Timken bearings included.
$200 shipped.
ID:	79635   Click image for larger version
90, d90
Center Diff Lock Issues (on, off, or in-between) Heath Defender Technical Discussions 10 October 29th, 2017 01:39 AM
HD diff centers - Truetrac and LR HD 4-pinion DaveC For Sale - Parts 0 September 5th, 2013 03:54 PM
Land Rover defender snorkel $200 shipped larrynsr For Sale - Parts 2 December 18th, 2011 03:26 PM
QT Services Diff Guards and HD Engine Mounts JohnC The Vendors Loft 1 February 16th, 2006 09:53 PM
