Left over stuff from my Clutch Job - Seals and what not for trans, transfer, etc - Defender Source
Old April 15th, 2012, 11:11 PM
bjf's Avatar
bjf
barry f
94 ST #395
I bought too much stuff when I changed my clutch. I have the following for sale:
Proline Rear Main seal - oil seal rear crank $12
Genuine FTC500010 oil seal extension case r380 gearbox $24
Genuine 549911 Pilot bushing - pinion/crank v8 $5
Genuine transfer case gasket set for the lt230. Includes all the gaskets needed to reseal the entire case. $70
All prices include shipping. All parts are new and still in the packages.
Old April 15th, 2012, 11:13 PM
bjf's Avatar
bjf
barry f
94 ST #395
Some pics
ID:	50369   Click image for larger version
ID:	50371   Click image for larger version
Old April 17th, 2012, 11:36 AM
bjf's Avatar
bjf
barry f
94 ST #395
bump
Old April 17th, 2012, 11:36 PM
So what ended up being your transfer case leak if you didn't use the seal kit?
Old April 18th, 2012, 12:35 AM
bjf's Avatar
bjf
barry f
94 ST #395
The access plate leaked. Easy fix
Old April 18th, 2012, 07:08 AM
Did you just "right stuff" the access plate? I'm planning to do mine.
What gives with the rear pinion? Breather tube clogged?
Old April 18th, 2012, 10:40 AM
bjf's Avatar
bjf
barry f
94 ST #395
Used right stuff as the paper gasket seemed dumb.
Not sure about rear pinion. I cleaned it up to see if it is really leaking or just years of grime.
Next job is to replace the steering pump and line again.
Old April 18th, 2012, 10:49 AM
Actually depending on how back the tcase was leaking, you could get blowback on the rear diff that makes it look like the pinion seal is leaking (when it is not).
Arbitrary question - any idea what you torqued the tcase bolts to to snug it back up? I plan to do mine this week but haven't been able to find that...not that it's a huge deal, I can just wing it but figured you're anal retentive as f*ck so you may know.
Old April 18th, 2012, 10:54 AM
bjf's Avatar
bjf
barry f
94 ST #395
Ha I am anal retentive as fuck but didn't use the torque wrench on the plate.
My access plate has been leaking for five years so it probably was just that.
I feel lucky and shocked it was just that.
I filled everything with royal purple btw and notice no difference but it shifted well before so I guess there is no reason I would see a difference.
Old April 18th, 2012, 11:45 AM
bjf's Avatar
bjf
barry f
94 ST #395
Shit wasn't I responsible for that. I just went tighty righty.
Old April 19th, 2012, 05:20 PM
bjf's Avatar
bjf
barry f
94 ST #395
No one needs this shit? Suddenly rovers don't leak.
Old May 22nd, 2012, 09:10 PM
bjf's Avatar
bjf
barry f
94 ST #395
90 for all of it.
No one needs this crap?
I want to get rid of all of it.
clutch, seals
