Landrover Autobiography Bi-LED NOLDEN lights - Page 2 - Defender Source
Old March 16th, 2016, 05:35 PM
Rugbier's Avatar
Rugbier
Gustavo
Originally Posted by rivermike View Post
Gustavo, this is not included in the kit. These headlights are normally installed on trucks that have this function in the wiring loom. I can get you the switch for $ 75...
Mike, thanks for the response
And how does switch connect to
Is there a harness needed ?
NO SIGNATURE
Old March 16th, 2016, 06:57 PM
Headlight leveling requires motors to move the headlight itself.
Much more than just a switch.
Old March 16th, 2016, 07:04 PM
Rugbier's Avatar
Rugbier
Gustavo
The motors are included, what I am not certain is how the switch communicate to the motors, and how those motors connect to the lamp
NO SIGNATURE
Old March 16th, 2016, 07:28 PM
Think you'll need to register to see the first wiring diagram.
https://www.landyzone.co.uk/land-rov...switch.141808/
Old March 16th, 2016, 07:43 PM
Rugbier's Avatar
Rugbier
Gustavo
Yeah, saw that
But I read ( can't find it now so I pinged Mike ) that the switch goes straight to the headlamp as the motor is inside, so I was wondering how the switch connects to them
I am sure on the modern 2004 and up ( see new fascia comment on your link ) there has to be a harness in there from factory and wondering how the application will work to older models as I do not believe there is another piece of equipment between the switch and the headlamp 3 prongs
NO SIGNATURE
Old March 16th, 2016, 11:37 PM
doktorno
Chris deZ.
1995 Defender SW
Fused power and ground to both headlight motors, and the switch. The switch positions vary the resistance in the blue wire according to the schematic shown in the link. Based on the schematic there is nothing between the switch and the blue wire.
Old March 17th, 2016, 12:04 AM
Rugbier's Avatar
Rugbier
Gustavo
I have found this , there is a harness from the Headlamp motor to the main harness and similar behind the fascia on the newer models
Name:	Screen Shot 2016-03-16 at 11.56.21 PM.png
ID:	145203   Click image for larger version
Name:	Screen Shot 2016-03-16 at 11.55.59 PM.png
ID:	145205   Click image for larger version
Name:	Headlamp with motor.png
NO SIGNATURE
Old March 17th, 2016, 12:35 AM
D90Overkill's Avatar
D90Overkill
David Frank
1995 ST #2615
I'm racking my brain about this leveling switch and where to install it in a '95 NAS ST. It's pretty obtuse. Is it even necessary after initial install of the lamps? It could be fun to manage the array, but is it likely to be used even 1% of the time? Ideas anyone? Cigarette lighter is all I can come up with barring putting a hole in my lower dash. My left side aux light switches are full and I don't have a/c, so those are out. Could it be disassembled to just the switch, and not the positive point markers, so that it could sit relatively flush?
Old March 17th, 2016, 03:26 AM
rivermike's Avatar
rivermike
Michael
2008 LHD Tdci 110 Keswick Green
This is also fitted to the earlier 1996 / 2001 300 tdi Defenders, see location in the pic below
Name:	headlight levelling switch location 300 tdi.jpg
For LHD Defender restorations and refurbishments
WEBSITE :
EMAIlL :
Current Inventory is listed in my STOCKLIST section
Worldwide shipping is our specialty
Old March 17th, 2016, 10:02 AM
doktorno
Chris deZ.
1995 Defender SW
My German cars run euro lights with adjusters, and ran them for years without the adjusters operational. Only time I see the adjusters as necessary is if the back of the vehicle is lowered due to weight and you want to avoid blinding oncoming traffic. Both of my cars have self leveling suspension, so I never need the adjusters. Since the Defender is so softly sprung, seems like the adjuster is good thing to have. Hide the switch under the dash, you will not use if very often.
Old March 18th, 2016, 07:29 AM
rivermike's Avatar
rivermike
Michael
First couple of sets despatched now , payment recieved with thanks from Mark, Jeffrey and Chris
WEBSITE :
EMAIlL :
Old March 22nd, 2016, 10:29 AM
rivermike's Avatar
rivermike
Michael
Sets for JP and Mark Staff despatched
WEBSITE :
EMAIlL :
Old March 23rd, 2016, 06:26 PM
prestige
Justin
1984 Defender 90
PM sent
Old March 27th, 2016, 02:59 PM
rivermike's Avatar
rivermike
Michael
First couple of sets delivered in the US
WEBSITE :
EMAIlL :
Old March 29th, 2016, 02:33 PM
doktorno
Chris deZ.
1995 Defender SW
My set arrived safely, and they look great. Quality unit.
Old March 29th, 2016, 02:44 PM
rivermike's Avatar
rivermike
Michael
Wow that was quick ! Glad to hear that ... thanks for your comment. They are dead easy to install, just Plug and Play.
WEBSITE :
EMAIlL :
Old March 31st, 2016, 04:14 AM
lithium1330's Avatar
lithium1330
'97 SW NAS 4.6
Would someone post light pattern and brightness comparing before and after, please?
Or maybe one old lamp and other new?
Thanks!
Old April 3rd, 2016, 03:15 PM
Avahdani's Avatar
Avahdani
Nushi
NONE
Anyone tried this on their NAS model. How is it compare to trucklite?
Old April 3rd, 2016, 06:57 PM
WI-ROTTIE's Avatar
WI-ROTTIE
Pete Bethke
'95 D-90 SW #305
Hi Mike,
I'll take a set. Sent u email. Thx!
'95 SW #305
'05 LR3 HSE
'07 RR
Old April 3rd, 2016, 08:10 PM
Stormer's Avatar
Stormer
JP
2008 RRSC
Put them on the TD5 and the 130. Look great.
"These are the best traveled nuts on d-90 . . ." ABrooks
ht, lights
Nolden LED Headlamps TRS Defender Technical Discussions 8 April 9th, 2016 02:35 AM
Overland autobiography by Andrew St. Pierre White Overlander Misc. Chit-Chat 0 June 23rd, 2015 09:48 PM
How to Convert 1994 rear Square Lights to 95-97 LED lights FlaD90 Defender Technical Discussions 7 November 20th, 2011 05:34 AM
