land rover supercharger - Page 2 - Defender Source
Old April 12th, 2013, 09:18 PM
Ray_G's Avatar
Ray_G
Ray Gerber
Originally Posted by The Dro View Post
This is a smoking deal.
Bolt-on SC... You cannot beat that.
Bolt on forced induction...ah, the idealism.
Old April 12th, 2013, 09:44 PM
The Dro
Dro
1988 Ninety
LOL!
At least is less work. It's already mounted to a Rover V8.
Old April 12th, 2013, 09:49 PM
Arcadeus's Avatar
Arcadeus
Mark Bichin
97 NAS Station Wagon LE
I meaning what kind of torque/ hp gain... Do you need to pull the engine to instal it? Will the same engine management system work or will it come with another? Chip? Don't these engines blow head gaskets? Will you need to oring the block?
Potentially interested pending answers...
Old April 12th, 2013, 09:59 PM
The Dro
Dro
1988 Ninety
Probably 100 HP and you'll need to remap.
Old April 13th, 2013, 12:40 AM
RoverLover5023
Alejandro
1965 Series 2a
Well dont need to pull the engine. This unit is a direct bolt on. Hp gain verys from the pull system you use. I calked cameron concept in ca (now name something else) amd spoke with one of the install tech there and he explained to me that is was an easy install and no remapping or larger injectors were used. When peter cameron got promission from land rover special vehicle to install this unit, they kept it simple. They added a high performance exhaust. I also asked about adding it to a 4.6 and 3.9 all you need to make sure you have a return line like what's on it now
Old April 13th, 2013, 07:11 AM
MUDSUX's Avatar
MUDSUX
Forrest
Like my Tatas?
Alejandro,
I sent you a private message yesterday about the motor. Did you get it?
MUDSUX
Old April 13th, 2013, 07:16 AM
Ray_G's Avatar
Ray_G
Ray Gerber
100 HP? Is this one of those 'at the crank' estimates that translates (through parasitic loss of course) to 25hp at the wheels. That would be significant indeed on a true bolt up with no fuel mods. I'd expect it to be hitting about 6 psi at most given the stock parameters, and given that I think a more conservative estimate would be 40hp. 40hp on an engine that is realistically putting down 170 is not insignificant mind you so don't get me wrong, the SC would be a nice bump in performance but I don't think you should expect to make the dump truck into an EVO. Having played with enough FI in my life my comments were meant mostly to caution about just bolting on with no other changes-you can do it, but don't expect dramatic results and anticipate that the added stress on the engine may be problematic over time. How much time depends on a variety of things ranging from condition of the engine and ancillaries at the start to how much skinny pedal you use.
But who knows, maybe this is the answer to Jonathan's desire to fulfill his Lone Wolf destiny and if his Disco was buried in a hole by a crime syndicate the SC would allow him to dig his way out on HP alone....
Old April 13th, 2013, 12:07 PM
RoverLover5023
Alejandro
1965 Series 2a
Hey Forrest, yes i did get your private message and i sent you one back..please send my your contact info..
Old April 13th, 2013, 12:17 PM
MUDSUX's Avatar
MUDSUX
Forrest
Like my Tatas?
Hey I never got your PM but I'll send it over. Thanks
MUDSUX
Old April 14th, 2013, 01:02 AM
cupgt
Ian
98 Discovery
MegaSquirt, injectors, tune and keep your fingers crossed! Id be scared shitless to put boost to a rover motor but it would be cool as shit!
Old April 14th, 2013, 02:50 AM
Arcadeus's Avatar
Arcadeus
Mark Bichin
I was doing some reading about these supercharges. They need a modified hood to fit them.
Old April 14th, 2013, 08:37 AM
Puma
Old April 14th, 2013, 08:51 AM
FWIW I saw a 96 gems 4.6 p38 fitted with an eaton supercharger last night @ Uwharrie Safari and the thing was bad ass. I was talking to the guy and he said the supercharger on a gems 4.6 made it equivalent to a bosch 4.6 in performance but with a load more "cool" factor. Tt sounded incredible and yes the p38 had a hood scoop..
Old April 14th, 2013, 09:02 AM
RoverLover5023
Alejandro
1965 Series 2a
Mudsux...I got your email..ill email later today..I did find that Shane over at the rover shop fitted the same type of sc on a d90 and cleared the stock hood. You can find the pics if you search sc under rover shop..so maybe there is a way. Yes before the blown gasket this thing was pretty bas ass as for as performance when you needed it!
Old April 14th, 2013, 09:09 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Alejandro, I'd be curious to know the REAL mpg the previous owner was getting in this p38.
And no BS 18mpg either!
I'd seriously like to know how much gas the SC eats up on a daily basis in a DD.
We here all know what to realistically expect MPG-wise from a 4.6 but not many here can give real world numbers from a SC mpg!
Old April 14th, 2013, 09:10 AM
MUDSUX's Avatar
MUDSUX
Forrest
Like my Tatas?
Thanks I look forward to it.
MUDSUX
Old April 14th, 2013, 09:41 AM
I've seen it too, many times with the stock hood. I could see it being tight on the P38, but there are many examples of them fitting Defenders without any body modification needed.
Old April 14th, 2013, 12:08 PM
Arcadeus's Avatar
Arcadeus
Mark Bichin
I was reading that they clear the hood... Just... They touch most times... But they usually kill the paint there due to the heat buildup... I can find the link that someone had it in a 97 NAS Le... Maybe depends on how heavy you use it?
Old April 14th, 2013, 08:31 PM
Paul Davis's Avatar
Paul Davis
Paul Davis
97 ST
I average 10 mpg city and about 10.5 mpg highway with what looks to be the exact set up I have. Granted that's on a 4.0 90 with 35's. Also, I'm a little overweight. Anyway, that's the mpg I see with a very similar set up.
Old April 14th, 2013, 11:06 PM
Arcadeus's Avatar
Arcadeus
Mark Bichin
We are not judging you here
Supercharger cdb For Sale - Parts 5 September 25th, 2012 07:17 PM
Anyone still running a Rimmer supercharger cdb Defender Technical Discussions 24 April 2nd, 2011 06:42 PM
TVR Supercharger for Rover V8 Doug Misc. Chit-Chat 2 January 27th, 2006 04:43 PM
Rimmer Supercharger, complete. Also side fuel tank. Tom Fitzgerald For Sale - Parts 14 December 12th, 2005 08:09 PM
Supercharger jorge Defender Technical Discussions 2 November 20th, 2005 07:21 PM
