Ignition Amplifier Module Relocation Kit (STC1856) - Page 2 - Defender Source
Old November 22nd, 2010, 08:46 PM
Whoever came up with the notion that the ignition module had to be relocated must have been high on something. It's 100 percent absolutely fine where it is. I do keep a spare in the cubby box tho...
Old November 22nd, 2010, 08:50 PM
Abrooks's Avatar
Abrooks
Tony Brooks
Feh. It cured a longstanding issue with the ignition system in my '94 and has for many others. Leave that spare at home and tempt fate . . .
Old November 23rd, 2010, 07:55 AM
Disagree
Old November 23rd, 2010, 11:52 AM
Disagree
You are nuts.
Ignition modules don't do well with heat and on the dizzy it cooks, on the fender it stays cool (and is 10x easier to change). How you change one in situ on the side of the road without pulling the dizzy I would like to see.
PS no offense intended.
Old November 23rd, 2010, 12:29 PM
Neil McCauley's Avatar
Neil McCauley
Neil McCauley
94 ST, 97 ST, 93 110
I was actually able to remove the ignition module without taking the distributor off, I was at home of course but it was kind of a bitch. Wouldn't want to do it off the side of the road. You have to take off the vacuum advance screws, than the advance itself, rotate the distributor to the front, it helps to loosen the alternator bracket and push it to the side, which is what I did, then I was able to access the screws with my tiny socket set. Hey is there a substitute for that white silicone that comes with the ignition module that I can use? What if I use dielectric grease or just regular silicone, will it make a difference?
Robert Deniro
Old November 23rd, 2010, 07:21 PM
I believe it's the same thing you put on heat sinks on computer CPUs - it's a conductive paste to allow a good connection between the module and the mounting plate to dissipate heat.
Old November 23rd, 2010, 07:39 PM
Neil McCauley
Neil McCauley
lol do they sell that at frys? I'm going the Mallory route finally so hopefully I won't need this for much longer.
Robert Deniro
Old November 23rd, 2010, 07:52 PM
Yup
http://www.frys.com/product/6274350
------ Follow up post added November 23rd, 2010 07:53 PM ------
BTW, I expect nothing less than a picture a young lady's exposed buttocks with N and M drawn on them with the remaining paste, since you don't need much for the job.
kit, mod
Distributor OR Ignition Module? tdn Defender Technical Discussions 12 December 7th, 2010 12:52 PM
Does STC1856 replace ignition module? or just move it? btate Defender Technical Discussions 0 July 17th, 2006 08:08 AM
Ignition Relocation = No Start...Help JRowe Defender Technical Discussions 5 March 8th, 2004 12:45 PM
Ignition Module Relocation: Help JRowe Defender Technical Discussions 21 March 7th, 2004 11:45 AM
