Hydraulic Milemarker winch and RN bumper - Defender Source
Old March 22nd, 2014, 08:24 PM
Abrooks's Avatar
Abrooks
Tony Brooks
This is taking up valuable space in the garage and needs to find a truck to call home. Mile marker hydraulic winch and RoversNorth winch bumper. The bumper has been slightly modified for the winch (extra mounting feet). Winch needs to be replumbed once installed. Includes manifold and solenoids, worked when removed but new o-rings and lines would be prudent. Bumper is in good condition, includes one Dixon bate recovery point and mounting holes for another. You can see it on the RN site. Fresh paint wouldn't be a horrible idea. What you see in the pictures is what you get.
$1475 OBO. Pick up in northern VA only, will not ship.
ID:	91639   Click image for larger version
ID:	91641   Click image for larger version
ID:	91643   Click image for larger version
ID:	91645   Click image for larger version
Old March 24th, 2014, 09:02 AM
Abrooks's Avatar
Abrooks
Tony Brooks
Will happily RURR.
Old March 24th, 2014, 09:41 AM
Spenc1tj's Avatar
Spenc1tj
TJ Spencer
1997 NAS Defender
What does RURR mean?!
Old March 24th, 2014, 09:43 AM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Rover underground rail road.
Old March 24th, 2014, 10:13 AM
The Dro
Dro
1988 Ninety
We even have stickers
Name:	Photo Oct 16, 2 46 32 PM.jpg
Old March 24th, 2014, 09:26 PM
Abrooks's Avatar
Abrooks
Tony Brooks
Looks like I was late to answer that one!
Old March 25th, 2014, 09:54 PM
Abrooks's Avatar
Abrooks
Tony Brooks
Just tripped over the bumper. Toe hurts. $1200
Old March 26th, 2014, 01:41 PM
RockShow's Avatar
RockShow
Ben Goodwin
1996 D1
I know very little about the specifics of setting up a hydraulic winch. What is missing from this set up? I don't see a pulley on anything so I am guessing there is no pump? Do you have any info on which pump would be required or done any research on what it will cost to have it up and running? Is it a belt driven pump on the motor or pto driven? If pto, will it still work with LT230?
Old March 26th, 2014, 01:46 PM
ranewman's Avatar
ranewman
Rick Newman
85 Defender 110
Do a search on the mile marker. There are different configurations that this can be set up with. The pumps range from a power steering set up, to the set up for an exmod. Then again there is a whole section on pto powered systems.
Rick
06 L322 Range Rover "The Black Pearl"
06 L322 Range Rover "2.0"
97 Disco SD "Emma" (250k and going strong)
95 P38 "Gus" RIP
99 P38 Callaway Edition #106 RIP
85 Defender 110 2.5NA "Margret"
01 D2 SE7 "Cuzn It" (blown up POS)
03 D2 SE "Fred"
Hoarder of 2.5 NAD parts
"In God we trust. Everyone else keep their fucking hands where they can be seen."
Old March 26th, 2014, 02:38 PM
RockShow's Avatar
RockShow
Ben Goodwin
1996 D1
Any idea ballpark what the set up would cost in addition to the winch?
Old March 26th, 2014, 02:50 PM
ranewman's Avatar
ranewman
Rick Newman
85 Defender 110
I was thinking of a PS setup for my truck. Ball park was an additional $500 to $700 (reservoir, pump, brackets, hoses), not to mention the possibility of another fluid to leak from under the truck.
Rick
95 P38 "Gus" RIP
03 D2 SE "Fred"
Old March 26th, 2014, 02:55 PM
If you've got a gas V8, you can use the existing power steering pump. There is an adapter kit from Mile Marker for the Discovery 1, which is the same kit you'll need for the D90 gas V8.
I forget how much it was.
For extended winching, you'd probably want to add an oil cooler at the very least, and maybe a bigger reservoir tank.
If you want to be totally badass, you'd bracket up an electric clutch driven hydraulic pump.
I wouldn't drive one from a transfer case PTO, cz when you push in the clutch the winch stops. That and the crazy amount of hosing needed.
Old March 26th, 2014, 08:33 PM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
I don't see a problem with that. One plus of hydraulic is you can winch properly and not have to put power to the wheels. The winch does all the work like they should.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old March 26th, 2014, 11:39 PM
Abrooks's Avatar
Abrooks
Tony Brooks
I really need toog in more often . . .
Old March 27th, 2014, 05:31 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Originally Posted by RockShow View Post
... will it still work with LT230?
Yes.
http://www.firstfour.co.uk/products/...-drive-systems
Same/very similar setup is available from a place in Australia also.
You can just get the PTO adapter and controls and source the pump and everything else here in the US.
With my Koenig PTO (transfer case driven) that I've had since '79, I've never thought to myself, "Damn, I wish it wouldn't stop running when I depress the clutch".
In fact I liked it enough that I bought another last year.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old March 28th, 2014, 02:50 PM
Abrooks's Avatar
Abrooks
Tony Brooks
Going up on Expo.
Old March 31st, 2014, 08:46 AM
Abrooks's Avatar
Abrooks
Tony Brooks
Bump
Old March 31st, 2014, 02:31 PM
Bricktop's Avatar
Bricktop
Jon Paulikonis
1998 Discovery
Tony - are you willing to separate the bumper out of the package?
Old March 31st, 2014, 02:32 PM
Abrooks's Avatar
Abrooks
Tony Brooks
Sure, shoot me an email!
Old April 2nd, 2014, 10:36 AM
Abrooks's Avatar
Abrooks
Tony Brooks
Everything is sold, thanks.
Hydraulic winch underpowered??? USLandy Defender Technical Discussions 7 December 18th, 2012 02:55 PM
milemarker electric winch discotdi Defender Technical Discussions 2 September 2nd, 2009 08:17 PM
Identify this hydraulic winch aclarke Defender Technical Discussions 0 December 10th, 2007 09:32 PM
MileMarker hydraulic winch purchase & setup aclarke Defender Technical Discussions 21 March 10th, 2007 02:17 PM
This might be handy for my Milemarker winch Hans Misc. Chit-Chat 2 January 4th, 2004 03:21 PM
