Hot Rod Rover V-8 Project - Defender Source
Old July 29th, 2014, 05:34 AM
madcowdungbeetle
Carter
I inherited this when I bought a giant pile of Defender/Series parts. Was going to use it, but I’ve decided to do something a little more Chevy. Fresh disassembled DIY hot-rod rover V8 long block for the home engine builder. From the original owner I was told all the machine work was done by D&D machine and/or to their spec and the overall design “was to D&D’s spec” with regards to components, bearings, etc. I would prefer to sell complete, but will part out if that does pan out. This is a builder engine and sold as such, meaning, make sure you know what you're doing when you build this, it's not a slap together kit unless you have intimate knowledge of the Rover V8. It has been covered, and stored coated with grease to prevent any corrosion. It is currently stored in a crate in the corner of my shop.
To my knowledge it lacks:
New pushrods, cams, oil pump/pickup
Here are the highlights:
Fresh reworked heads with new valves/rocker/spring setup greased coated for storage
New Rods
New Pistons w/ rings
Polished crank
Engine Block - it has 2-bolt mains - cylinders look great and have been greased coated for storage
Powder Coated Oil Pan
Powder Coated front cover
All new gasket kits
New timing chain kit
All new bearings, main, rod, etc...
Intake Manifold
4.2 ECU
Plenum drilled and tapped for AN fittings
Asking $1100 OBRO
ID:	99611   Click image for larger version
ID:	99613   Click image for larger version
ID:	99615   Click image for larger version
ID:	99617   Click image for larger version
ID:	99619   Click image for larger version
ID:	99621   Click image for larger version
Old July 29th, 2014, 05:36 AM
madcowdungbeetle
Carter
More Pics:
ID:	99624   Click image for larger version
Old July 29th, 2014, 09:03 AM
displacement ?
Old July 29th, 2014, 09:20 AM
madcowdungbeetle
Carter
It began it's life as a 4.2 off the top of my head. I'm not sure on the final displacement. I can pull numbers off the crank, rods and pistons for anyone that needs that info. I was told it should put down a solid 225-250hp when built and tuned.
Old July 29th, 2014, 09:25 AM
NPT90's Avatar
NPT90
JT
D90 óriginalé
impressive, glws
Old July 30th, 2014, 12:05 PM
madcowdungbeetle
Carter
Just to put it out there, I'm very negotiable on the price. I'd really like to just get it out of my way.
Old July 30th, 2014, 12:36 PM
wantone
Rick Thompson
94 ST #1222
pm sent
Old July 30th, 2014, 04:33 PM
madcowdungbeetle
Carter
Originally Posted by wantone View Post
pm sent
PM'ed back.
Old August 5th, 2014, 01:49 PM
madcowdungbeetle
Carter
Still available.
Price drop to $950
Get this thing outta my way so I can by Puma stuff.
Old August 14th, 2014, 11:55 PM
madcowdungbeetle
Carter
$800..... or I may just part the whole thing out.
Old August 15th, 2014, 12:20 AM
D90Overkill's Avatar
D90Overkill
David Frank
1995 ST #2615
Maaaaaaaaaaan! So tempted! I'd pay more in shipping than what you're asking! Someone buy this and put me out of my misery thinking about it! GLWS
Old August 15th, 2014, 01:02 AM
cbfritz_03
Carmen
none
I think you'd probably pay a couple hundred +/- for shipping. Use Fastenal. If you really want it you should buy it before he parts it out. In post #6 he says he's "very negotiable"...?
Old August 15th, 2014, 01:24 AM
D90Overkill
David Frank
1995 ST #2615
Thanks. I'll look into Fastenal. I know he's very negotiable but I just hate to haggle with someone already giving me a good deal.
Old August 15th, 2014, 01:43 AM
cbfritz_03
Carmen
none
I know and I feel the same. I just wanted to point out there was no reason not to get it ...
Old August 15th, 2014, 10:35 AM
madcowdungbeetle
Carter
I can ship surprisingly cheap via FedEx freight. My work has a baller account with them... make me an offer.
Old August 15th, 2014, 02:28 PM
D90Overkill
David Frank
1995 ST #2615
Pm'd
Defender 110 Tie Rod Steering rod change tjfslaughter Defender Technical Discussions 23 December 14th, 2011 10:53 AM
1998 range rover convertible one-of-a-kind 4x4 sut like hot rod street rod Capt Milks The Flea Market 0 December 2nd, 2011 07:06 AM
Equipe Panhard Rod and HD Track Rod Rugbier For Sale - Parts 14 March 23rd, 2011 09:27 PM
Tie Rod/Track Rod joint removal....aarrrrghh DNinety Defender Technical Discussions 5 October 24th, 2010 01:08 PM
A/C Help......hot, hot, hot! boulderbear Defender Technical Discussions 7 August 26th, 2006 07:54 PM
» Defender Registry
Oliver
IvanKV
CT 25
CamelTM
Add your Defender
