HELLA Twin Supertone Horns - Page 2 - Defender Source
Old September 3rd, 2010, 07:30 PM
Just installed. They're not quite as loud as I had thought, but they work (I was only blipping them though, so they're probably louder)! Dan, I gave you a call, but my horns weren't broken, just some wires were unplugged. I rewired them before uninstalling and they work fine. Yours if you need them!
Old November 12th, 2010, 01:29 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Josh.
Did the Supertone drop right into the stock wiring or did you have to swap out relay, etc?
I got this and plan to install it today if its easy. The stock horn is pathetic.
Old November 12th, 2010, 01:43 PM
Originally Posted by Manimal View Post
Josh.
It is plug and play with my stock wires. No relay swap was needed. Take a youtube video when you mount them...I'd like to hear yours in comparison to mine, as I believe mine buzz a bit.
Old November 12th, 2010, 02:36 PM
Jon_Winningham's Avatar
Jon_Winningham
Sterling M Archer
1995 AA Yellow NAS D90 #2986
I have the same hella horns and just wired them up to the old horn wires. I thought they would be louder too, but wonder it they are not getting enough juice since I am using the old wires and did not do the relay swap. And there is a slight buzz.
1995 NAS Defender 90 AA Yellow #2986: Current
2009 Range Rover Supercharged Black/Black: Current
1993 NAS Defender 110 #375/500: Sold
1995 NAS Defender 90 Soft Top Beluga Black #2556: Sold
1991 Range Rover Hunter Green: Sold
1997 NAS Defender 90 Station Wagon Portofino Red #128: Sold
1993 NAS Defender 110 Beluga Black #215/500: sold
Old November 12th, 2010, 02:51 PM
Good to know! It always makes me feel better when someone else has the same problem(s).
Old November 12th, 2010, 08:13 PM
Chaucer
Will
93 110 | 97 90
I thought it was required to install with a relay? I don't believe the stock setup has a relay does it?
Old November 12th, 2010, 09:44 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
I just installed mine. Plugged them into existing wiring without adding new relay. I read somewhere that these are directional so they should ideally be placed in front of radiator (behind grill) facing forward for loudest output. I can't do that because my Allard Intercooler takes up all the room. My current horns (and new ones) were mounted behind and above the right headlight.
I tested them while laying outside on the wing and holy f**k they are loud. 118db advertised. Once I placed them inside and shut the hood they were quite a bit less loud than when laying outside. So if you can mount them behind the grill. The TD5 headlight trim has vents between the turn signal and front marker for the horns to go through unobstructed. Makes sense since it seems to make quite a bit of difference.
They're still louder than stock and I prefer the tone better. No buzzing for me. So does the stock horns have a relay then or not?
horn
Hella Twin Supertone horns Cred For Sale - Parts 9 July 27th, 2010 06:33 PM
Hella Trumpet horns - replacement dmarchand For Sale - Parts 3 June 30th, 2008 05:05 PM
Hella Driving Light Add - Best? Kimos Defender Technical Discussions 43 October 26th, 2006 01:16 AM
Mounting Hella 4000s with Stock Bumper/Brush Guard jbird Defender Technical Discussions 5 June 10th, 2004 06:01 PM
Hella 3000 light covers mpodgorski For Sale - Parts 5 May 18th, 2004 02:05 PM
