Great Big Alternator - Defender Source
Old October 21st, 2013, 11:50 AM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
For sale is a custom Genuine remanufactured 180amp alternator for a D1/RRC/D90 serp belt setup. Truly a beautiful beast, comes with stickers and gum.
$450 shipped obo
ID:	82531   Click image for larger version
ID:	82533   Click image for larger version
Old October 22nd, 2013, 03:59 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Bump, two people interested but no takers. This is OBO.
Old October 22nd, 2013, 04:20 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
I'd be all over this if it wasn't for a serp truck. If you don't mind my asking, where did you get it? I'd like to find something similar for my truck. I'm ok with sending out my current one or even to doing it myself if I can source the parts somewhere.
Old October 22nd, 2013, 04:21 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
My mechanic's uncle builds them. I think he used 2-3 standard ones to create this one. I'd be happy to ask if he'd make you one if you want?
Old October 22nd, 2013, 04:32 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
Yeah, that would be great! I can send him mine and he can use the case etc.
Old October 22nd, 2013, 06:34 PM
ROVERMAN1's Avatar
ROVERMAN1
Freddie
83 110 & 1993 NAS 110 1997 XD
Nice, but way above my budget
Old October 23rd, 2013, 05:41 PM
MonLand
Loic Fabro
95 D90 - 96 Disco -06 LR3
Beside the pulley, I don't think there is much difference between serp and v-belt setup. You might argue that the alternator might not turn at the right speed and not generate the right rpm signal for the gauge, but I'm sure you could get used to that mental conversion quickly! or maybe I'm missing something else?
MonLand
1995 D90 NAS
1996 Discovery NAS
Old October 23rd, 2013, 06:03 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
Does anyone know if this is true? If it will fit right on and I can just swap the pulley, this may work. Also, can someone chime in on the signal output? I don't want the gauges reading improperly, but I'm not sure it will, if I recall, the pulleys are similar in size.
Old October 23rd, 2013, 06:34 PM
Presumably it comes down to pulley size and therefore gearing.
Over speeding would be bad!
Old October 24th, 2013, 09:25 AM
MonLand
Loic Fabro
I'm sure someone will provide more details as I am sure someone tried this before. Signal output is based on rpm of the alternator. So if alternator turns faster than "expected" then engine rpm will read higher for sure. Engine rpm gauge might have to be recalibrated (if one cares).
Disco pulley is a bit smaller than D90 in diameter if I remember correctly (well, that's v8 3.9L v-belt D90 vs v8 4.0L Disco which I own). I have a few disco alternators I can measure tonight. The depth of the Disco alternator was a tad smaller than the D90 one but I did not see any reason why that would not work in a 90. I had both out at the same time a few weeks ago, so my memory is kinda fresh but I could still be wrong!
The 4.0L serp pulley was definitely a tad smaller (diameter) than the 90. If I remember correctly, it is also a tad narrower (at least has one less rib than my D90 belt/pulley).
Too bad this discussion is happening now... Just a few weeks ago I could have tried to put the disco alternator in my 90 and report.
Based on the difference in size of pulley, I would be hard pressed to think that the D90 alternator would be stressed in a disco. A disco alternator in a 90 would turn a little slower but I'd be surprised if we would see any difference in actual output. The Disco needed more output for sure since it has all the fancy high-output lights, gps, etc.
------ Follow up post added October 24th, 2013 09:26 AM ------
Maybe we should move this part of the conversation to the tech section instead of taking over a for sale post....
MonLand
1995 D90 NAS
1996 Discovery NAS
Old October 24th, 2013, 09:27 AM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
It's cool with me Loic, just giving me free bumps here
Old October 28th, 2013, 09:05 AM
MonLand
Loic Fabro
Bump then!
MonLand
1995 D90 NAS
1996 Discovery NAS
Old October 29th, 2013, 05:47 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
Further research leads me to believe it would be more involved than swapping the pulleys, so unfortunately I'm out.
Bump for a great Alternator though, good luck with your sale!
Old October 29th, 2013, 06:33 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
I believe the casting itself is different as well, more than just a small job to adapt. Thanks for looking!
Old October 31st, 2013, 06:35 PM
cupgt
Ian
98 Discovery
Zack, donate it to me for my weekend warrior wheeling trips! Ill hand out your business card and put stickers all over my truck!
Old October 31st, 2013, 06:50 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Only if proven necessary for overland adventure.
Old November 1st, 2013, 12:44 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Price drop to $375 shipped, he'd like to get rid of it.
Old November 4th, 2013, 10:53 AM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
$350 shipped.
alternator
Alternator Campbell Defender Technical Discussions 4 July 12th, 2005 07:59 AM
Big Sky Rover mhansen Defender Technical Discussions 2 May 17th, 2005 09:11 PM
Dual Batts and HO Alternator jamesriding Defender Technical Discussions 42 January 9th, 2005 04:27 PM
Great New Pics Posted TDI Guy Misc. Chit-Chat 5 December 12th, 2003 09:35 AM
Great job Chris! Rick Carlisle Support & Suggestions 5 October 2nd, 2003 10:58 PM
