GM 6.5 Diesel Conversion - Defender Source
Old March 16th, 2008, 07:46 PM
RyanS's Avatar
RyanS
Ryan
'93 NAS 110
I had this drivetrain in my 110, but have now gone to a 2.8 PS. I would prefer to sell it complete, but will sell separately if necessary. I may also consider parting out the 6.5 since there are a lot of premium parts on it.
Here's what's included:
GM 6.5 Diesel w/Banks Turbo
20.5:1 Compression Ratio
Artic Injection Pump
Gear Drive Timing Set
Vacuum Pump
Gear Reduction Starter
Single Mass Flywheel
GM Bellhousing
High Volume Water Pump
Dual Thermostat Crossover Housing
Ample Power 124A Alternator
High Flow, High Pop Injectors Recently Installed
Quick Heat Glow Plugs Recently Installed
Luk Clutch Disc and Pressure Plate Recently Installed
Exhaust Downpipe
7-Blade Fan w/Viscous Clutch
Banks EGT Gauge and Sensor
Injector Socket
Block Heater
Ample Power Next Step External Regulator
Spare Thermostats (2)
Spare V-Belts, Dayco #'s 15475 and 15490
Spare Exhaust Donut Gasket
Spare Oil Filter, Fleetguard #LF3488
Spare Exhaust Flange Springs and Nuts (3)
Spare HPCA Switch
Spare Oil Drain Plug Washers (2)
Spare Turbo Drain Gaskets (2)
Spare South Bend Clutch Disc
Spare Pressure Plate (Used)
Spare Glow Plugs (8 Used)
6.5 Troubleshooting Guide
Ample Power Next Step Regulator/Alternator Instructions
6.2/6.5 1997 Articles
6.5 Turbo Diesel Workbook
GM Service Manuals (2 Notebooks)
NV4500 Transmission (5.6 Ratio, 29-spline, Dodge Tailhousing)
Internal Slave Cylinder
Spare 5th/Rev Shift Fork (New)
Griffin Custom Aluminum Radiator
NV-LT230 Adapter Plate/Spud Shaft
Custom Slave Cylinder Hose for LR
Defender Motor Mount Fixture
Defender Front Crossmember
Defender Rear Crossmember w/Transmission and Transfer Case Mounts
Pricing:
Complete = $3000
6.5 Engine = $1800
NV4500 Trans = $1000
Radiator = $300
NV-LT230 Adapter = $800
Each item includes all of the parts described under the appropriate heading above.
Please PM me for further details.
Old March 17th, 2008, 10:11 AM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
Ryan- Why are you switching to the 2.8 PS? Any problems with the 6.5? How much modification did you have to do to fit the 6.5 to a 110 chassis - new brackets, cross members, intercoolers, etc? I have a project it may fit in, which is why I'm asking Any pictures with it in the 110? Email them, if you have them. Thanks.
Old March 17th, 2008, 11:43 AM
Gkase's Avatar
Gkase
George Kase
1983 110 200Tdi CSW LHD
Ryan,
I'm also curious about this conversion and how you did it...I was considering a 6.5L for my D-90 before deciding to go with a 300Tdi...what kind of mileage were you getting?
George
Old March 19th, 2008, 02:36 PM
RyanS's Avatar
RyanS
Ryan
'93 NAS 110
George - PM me your E-mail address, and I'll send you some more info.
Old April 6th, 2008, 02:53 AM
RyanS's Avatar
RyanS
Ryan
'93 NAS 110
Engine has been Sold.
conversion, diesel
Diesel Conversion Kits and Shops ChicagoDon Misc. Chit-Chat 25 July 31st, 2012 12:58 PM
More on diesel / manual conversions Delta95 Defender Technical Discussions 37 September 4th, 2008 11:31 AM
My take on economics of diesel conversion Gkase Misc. Chit-Chat 12 June 16th, 2006 09:29 PM
Diesel Conversion Experiences JimC Defender Technical Discussions 10 December 13th, 2004 05:22 PM
D110 Diesel conversion, towing. Kerr Defender Technical Discussions 3 May 5th, 2004 06:26 PM
