GBR 4.14 Front Reverse Rotation Extreme Duty - Defender Source
Old January 23rd, 2015, 07:03 PM
cdb
Clark Bowen
I never installed this ring and pinion. It is new in box: $300 plus shipping.
From the GBRUtah website:
"GBR exclusive – 7X29 tooth count/reverse rotation
This is an extreme duty gear set designed and manufactured to our specifications. It is designed to compensate for the vehicles differential gearing due to tire size increases and to reduce the overall gearing for increased off road performance and aggressive off roading.
These are a 7X29 tooth count, which is reduced from 9X37 in our Stage 2 – 4.11 gear kits. This coarser tooth count increases the durability of this gear set by 20% compared to our own 4.11 ratio. They are a reverse rotation design.They are interchangeable with 4.11 or 4.10 gears but can be up to 50% stronger. As a result these are the most durable mid ratio front Land Rover gears one can buy anywhere, at any price. When installed in a differential housing utilizing our Thrust Bolt kit, this is a brutally strong differential, significantly exceeding the strength of common conversion differentials such as Toyotas.
These gear sets are designed as a direct replacement for a stock 3.54 ratio. We can advise you of any other compatibility issues and supply any additional parts that may be required for proper installation
We can also supply completely reconditioned or remanufactured exchange differentials with these gears.
part number
description
price
GBR414HDC
$449.95"
2011 RR HSE -
2001 GMC 2500 4wd
Old January 27th, 2015, 08:14 PM
cdb
Clark Bowen
new price $250 plus shipping
2011 RR HSE -
2001 GMC 2500 4wd
Old January 27th, 2015, 08:47 PM
scrubs
henery
1974
Will pm tomorrow
Old January 29th, 2015, 07:11 PM
cdb
Clark Bowen
They are sold pending funds
2011 RR HSE -
2001 GMC 2500 4wd
GBR Heavy Duty Land Rover front drive shafts RoverDude For Sale - Parts 2 December 18th, 2013 02:11 PM
300TDi PSC reverse rotation PS pump Buckon37s For Sale - Parts 1 August 9th, 2013 12:00 PM
GBR heavy duty front shafts/CVs! crown14 For Sale - Parts 2 February 9th, 2011 12:26 PM
Front GBR Extreme Duty 23/24 inner axles, D110 CV's and spindles w/ brass bushing lwg For Sale - Parts 8 February 9th, 2005 01:08 AM
GBR 4.75 3rds and Extreme front axle setup for sale billnsandi For Sale - Parts 2 January 4th, 2004 11:10 PM
