GBR 4.11 gear kits and random parts - Defender Source
Old November 25th, 2013, 11:25 PM
DaveC
David Crall
1996 Discovery
Need to sell:
GBR 4.11 HD reverse cut front and rear gear kits, brand new in box from GBR (November 2013) including seals, pinion nuts, and all needed shims. $645 shipped
Also have:
HD LR 4-pinion differential - super strong open diff (P38 4.6 diff machined to work correctly for all 24 spline Rovers. $110 shipped
very good condition spare 24 spline CVs w/ front axles attached $80 shipped
Hydraulic grade engine and trans. oil cooler line rebuild kits. I put these together myself. All that is needed is the existing steel hard lines. Cost over $200. This is far superior to the stock rubber hose and crimp fittings. For D1 and probably RRC or D90. Rebuild all 4 lines. $100 shipped
Osram super bright 65 W low, 70 W high beam headlamp bulbs for Disco I. $35 shipped
Disco 1 genuine brush guard. excellent condition. $100
Safari Guard diff guard, excellent. $60 shipped
Atlantic British diff guard, good useable condition. $50 shipped
RR 4.6 GEMS ecu, excellent. $100 shipped
Parts located in MA, 01201.
Old November 26th, 2013, 07:40 AM
Roving Beetle
Doug
I'll take the 4 pin diff (complete third?) and the CV's with shafts.
Doug
Series coiler monster in building process, in gather parts mode.
Currently driving an ex-southern 1993 SWB RRC with too much "kit". Massive conversion and interior swap in process.
Lots, lots and lots more have come and gone....
Old November 26th, 2013, 11:55 AM
DaveC
David Crall
1996 Discovery
Doug
No' it's just the diff carrier from a 4.6 RR with the gear flange, webbing braces machined smaller and one bearing journal machined (mic-ed) so that the distance between bearings and gear relationship is correct for non-P38 Rovers. I had $175 in machine work done. This is a common thing in the UK. I have rebuilt the carrier to inspect the gears and clean any metal fillings, and its is in mint condition.
I can include a cleaned/ painted housing, all pinion bearings (excellent used), good 3.54 gears, and new Timken carrier bearings for $180 shipped.
-Dave
Old November 26th, 2013, 12:35 PM
Fearnofish's Avatar
Fearnofish
85 110 CSW
Are the 4.11 gears for the p38 or sals rear end? If sals the I'll take the rears.
Old November 26th, 2013, 02:33 PM
DaveC
David Crall
1996 Discovery
No, the gears are for regular Rover differentials (D90, DI, DII, RRC 24 spline).
------ Follow up post added November 26th, 2013 02:38 PM ------
Also have:
Thule super tall gutter rack mounts for Discoverys (and D90s maybe?). These are not the skinny ones with one clamp knob, they are wide with dual clamps and much stronger. I cn include two load bars with the 4 gutter mounts.
$100 shipped for the excellent cond., tall Thule gutter mounts.
and $120 shipped with load bars.
Old November 28th, 2013, 08:15 PM
DaveC
David Crall
1996 Discovery
everything still for sale
still have everything including;
Thule super tall, gutter rack mounts for Discoverys (and D90s maybe?). These are not the skinny ones with one clamp knob, they are wide with dual clamps and much stronger. I can include two load bars with the 4 gutter mounts. No rust.
kit, part, parts
Lawn Tethers (anchored into ground) for Dogs - Random Thread Warning rijosho Misc. Chit-Chat 26 April 5th, 2013 04:01 PM
