Fuel Pump /Gas Tank - Defender Source
Old January 14th, 2008, 07:27 PM
bjf's Avatar
bjf
barry f
94 ST #395
Fuel Pump /Gas Tank
Fuel Pump - 48,000 miles ( I assume it is orginal). I only replaced it because I pulled the tank out. Make me an offer.
Gas tank - It either has a hairline crack (about an centimeter) or deformation from original molding on one of the check valves on the top. It only leaked when the tank was filled to the top. I ended up replacing it but most people say you can use plastic fix like a jb weld to repair it for basically nothing. Search the boards and you will see this is a common problem with plastic tanks. If you are comfortable making a fix or need a tank for a project, this might be a good way to get one cheap. Make me an offer. Of course I don't think I can ship it.
I may also have the fuel tank vent assembly pipe which should work fine. No good offer will be refused.
fuel, gas, gas tank
Defunct In Tank Fuel Pump JimC Wanted 6 October 18th, 2004 03:18 PM
