fuel pump - Defender Source
Old March 8th, 2015, 11:45 AM
stuthegeordie
stu
1986/110 petrol 2.5
fuel pump
Hi all
So I put a new fuel tank on my 110 2.5 petrol, put in back together now it wont start. I dont hear the fuel pump on II. Any ideas on what it could be, Im hoping it can be diagnosed before dropping the tank again?
Cheers in advance
Old March 8th, 2015, 11:58 AM
1: No fuel
2: Fuse
3: blocked fuel filter
4: Does it fire when you use cold start?
Old March 8th, 2015, 12:03 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Where is your fuel pump located?
The 2.5 110 often has a small fuel filter in a housing located sometimes at the lower edge of the outside of the bulkhead and other times along the frame rail.
Usually a small round metal housing about 2.5 inches deep with a radius of about 2.25 inches.
These contain a small fuel filter element that often gets clogged and causes the electric fuel pump to fail.
Because they are out of sight most owners don't know they exist.
Find it and remove the whole assembly and install an inline filter just before the carb.
Also do the usual trouble shooting to make sure the fuel pump has power.
I was not aware that the 2.5 had a fuel pump inside the tank.
You should be able to buy a LOW PRESSURE 12V pump and mount it on the frame rail.
It has to produce no more than 2.5 pounds of pressure.
More than that will flood that shitty weber 34 carb.
RDavisinVA
Old March 8th, 2015, 12:14 PM
stuthegeordie
stu
1986/110 petrol 2.5
Thanks for that.
Yes fuel pump inside the tank.
I m a little low on gas, about 5 litres, but Im relectant to put more in incase I have to drop the tank again. I should hear the fuel tank humming regardless of it not having enough gas right? Not sure how to check if the pump is getting power its a sealed unit?
Cheers again
Old March 8th, 2015, 12:27 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Originally Posted by stuthegeordie View Post
Thanks for that.
Cheers again
Again, have never heard of a 2.5 fuel pump inside the tank.
We have both a 1986 & 1988 both with 2.5 Petrol engines here.
I'll check on fuel pump location, but anyone would be much happier with the fuel pump outside of the tank to cut down on the hassle of fuel tank removal to replace, trouble shoot, or service the fuel pump.
RDavisinVA
Old March 8th, 2015, 12:52 PM
stuthegeordie
stu
1986/110 petrol 2.5
I assume that because Im getting power to the fuel gauge Im also getting it to the pump as its off the same harness
Old March 8th, 2015, 01:12 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Not necessarily.
You need a good ground and (+) 12V.
RDavisinVA
Old March 8th, 2015, 01:27 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
The gauge and the pump are on different circuits. Silly question but did you connect a power to the pump? Robert is correct in that all of those vintage petrol motors had the fuel pump mounted on the frame rail forward of the RR wheel well. Could some previous owner installed a newer tank prior to your replacing the tank? That is if the old tank also had the fuel pump in it.
Old March 8th, 2015, 06:04 PM
stuthegeordie
stu
1986/110 petrol 2.5
The replacement tank was bought using the cars VIN and it matches the original so I guess it's the correct one for it.
Old March 15th, 2015, 07:11 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Today was able to get the 1988 110 with a 2.5 Petrol up on the lift and sure enough, could not locate the fuel pump. It was not on the frame rail, so Stu must be correct that it is in the tank.
RDavisinVA
Old March 19th, 2015, 02:02 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Here is the fuel tank and fuel pump from a 110 Parts List.
Note the petrol fuel pump is located inside the fuel tank.
If your pump is not running and you have (+) power to the lead, then you need to run a ground wire to the fuel tank.
If thereis no (+) current, you need to troubleshoot the circuit from the ignition to the fuel pump.
RDavisinVA
Old March 19th, 2015, 02:17 PM
Capt Milks's Avatar
Capt Milks
Robert, I have worked both on a 3.5 and 2.25 petrol 110's and they both had the pump on the rail. I guess they change it out depending upon the year. The trucks I worked on were a 83 and a 85.
Old March 24th, 2015, 04:12 PM
stuthegeordie
stu
1986/110 petrol 2.5
Sorted thanks for the replies.
Dodgy ground.
On the pump in the tank discussion, I was told that the 1986 was a change over year for the tank design by the tank supplier.
Old March 25th, 2015, 04:56 PM
belgian's Avatar
belgian
Maxim
1995 RRC SWB
Do you have a picture of this (110 is parked about 4 hours away so I'm not sure what to get) and the part number? Maybe that's what causing the fuel starvation on my 110. Thanks!
1984 Camel Trophy 110
1995 Range Rover Classic SWB
1992 Range Rover Classic SWB
Old March 25th, 2015, 05:17 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
It is shown in the attached picture as item 11.
It is located around the lower right side of the bulkhead.
RDavisinVA
Old March 25th, 2015, 05:23 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
It was my experience that the fuel pump was located on the frame as well.
Stu claimed his fuel pump was in the tank, and...
Sure enough, that's where the parts list shows it located.
This must have started very late 1986 or 1987 on-wards according to the parts list page in post 11.
I put our 1988 petrol 110 up on the lift and there is no pump to be seen on the frame... it's in the tank.
Stu was correct from the beginning.
RDavisinVA
Old March 25th, 2015, 06:01 PM
taoseno's Avatar
taoseno
Todd Kendrick
1995 D90 #2206 Original Owner
Need a brake line for rear PS NAS D90
I am looking for a new/barely used brake line for the rear passenger side. Out wheeling in the snow a couple weeks ago and bent it like coat hanger; see attached. Good news is crimped line so bad no fluid has leaked out. Anyone made there own brake lines? My concern is the odd fittings and how to overcome. Search was not my friend on this subject.......
Name:	Rear Brake Line.jpg
Todd
'95 D90 #2206
'66 109" P/U
Old March 25th, 2015, 06:45 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Todd:
You stepped into a fuel pump thread, so your post is misplaced.
I use the cupro-nickle line, but have an expensive mechanical double flaring brake tool I bought in England 20 years ago or longer.
RDavisinVA
Old March 25th, 2015, 06:51 PM
taoseno's Avatar
taoseno
Todd Kendrick
Sorry I just realized I posted in the wrong section; could the moderator please move to the "wanted" section? Thanks
Todd
'95 D90 #2206
'66 109" P/U
Old March 25th, 2015, 09:21 PM
done
fuel
TD5 Fuel Pump/ pump tomaco1 For Sale - Parts 7 September 20th, 2011 09:13 PM
feed 200tdi lift pump from Facet fuel pump ? kjva Defender Technical Discussions 1 September 7th, 2011 01:55 AM
Fuel tank skid / fuel pump / Dixon-Bate Tow Jaw chris snell Smaller Projects 16 September 2nd, 2010 12:29 AM
Diesel conversion - fuel pump removal and new fuel feed jaherring Defender Technical Discussions 0 July 19th, 2010 03:06 AM
Fuel pump and fuel gauge relationship question - troubleshoting... arbik Defender Technical Discussions 1 September 19th, 2006 02:31 PM
