FS: Under cubby console safe - Defender Source
Old July 21st, 2011, 02:13 PM
Chaucer
Will
93 110 | 97 90
FrontRunner Under cubby console safe.
$100 shipped obo.
Old July 21st, 2011, 02:36 PM
CDeWan
Clay DeWan
5.3L beastie
safe,
Will,
Do these fit under the car or in the interior? I have a center middle seat in the defender and wanted to know if this fits under the vehicle/seat or would impact the seat
Old July 21st, 2011, 02:57 PM
Chaucer
Will
93 110 | 97 90
Part of it goes under the interior just above the trans case/parking brake. The rest of it sits above the interior in place of a cubby. A cubby then mounts directly to the hinged lid.
Doesn't look like that would work for you.
Originally Posted by CDeWan View Post
Will,
Old July 21st, 2011, 05:02 PM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
ohh ohh... licked pending measurements.
Could you give me some measurements on the height above the floor, also length and width? I looked on their website and could find very little. How much clearance does it need behind it to open properly?
Old July 21st, 2011, 06:43 PM
themaxx's Avatar
themaxx
Ade
94 ST
second in line
Old July 21st, 2011, 06:54 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Third in line... which is not going to happen. So you would remove the middle seatbox door hatch and install this there? When installed it's not visible, right? I'm so getting one.
The only catch is, if you have a radio in your tuffy, what to do with the wiring underneath?
Old July 21st, 2011, 07:27 PM
D90user's Avatar
D90user
steve
I think if you are going to use the stock cubby it would raise it a couple inches. You would access the lock through the cubby and open her up. I could be completely wrong though.
I'm not running a cubby anymore because the pass through to the rear camper was difficult. This is going to be a low profile cubby for me which is perfect I hope.
If you still want a cubby and want it to actually lock get a tuffy... hey someone listed one just now!
Old July 21st, 2011, 07:36 PM
Chaucer
Will
93 110 | 97 90
Measurements:
Overall Height: 5 7/8" :
2" below seatbox level (where you remove the center cover plate).
3 7/8" above seatbox level.
Width: 10 3/8" (8 3/4" for the recessed part)
Length: 15 1/8"
I no longer have a Defender, so I can't see what type of clearance is necessary to open it. However, the top plate with the 4 holes for the cubby to attach to is 16 3/4" long.
Hope that helps.
------ Follow up post added July 21st, 2011 04:39 PM ------
Yes it would lift a stock cubby by roughly 4 inches.
Old July 21st, 2011, 07:44 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
I have a lockable Tuffy. I'm glad I did when I got broken into. This would be in addition to that. I'm not crazy about the fact that it raises the Tuffy up because then it can no longer be used as an armrest. A low profile version of this would be cool, one that would not raise the Tuffy. More stealth too.
------ Follow up post added July 21st, 2011 06:50 PM ------
Steve,
Do you have access to the rear of your camper through the cabin? I though you could only access from the back door. Post some improvement photos for us! Curious to see the progress.
Old July 21st, 2011, 07:52 PM
themaxx's Avatar
themaxx
Ade
94 ST
Another perspective... http://www.defender2.net/forum/topic928-30.html
Old July 21st, 2011, 08:32 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
After reading up on the thread you posted it appears that this is not compatible with a Tuffy that has a separate radio compartment. The lock for this box will end up in the position where there radio is so there is no way to access it. Someone should make a version compatible with the Tuffy.
Old July 21st, 2011, 10:17 PM
Chaucer
Will
93 110 | 97 90
Right it is not meant to be compatible with a Tuffy, but a stock cubby instead. Not sure if you would need one with a Tuffy as the Tuffy locks kind of redundant, but maybe someone would want that. I don't know.
Old July 22nd, 2011, 06:19 PM
D90user's Avatar
D90user
steve
I'll take it. Sending PM.
Old July 23rd, 2011, 07:25 PM
Chaucer
Will
93 110 | 97 90
SOLD! Thanks.
console, fs
FS: used CD changer 97 NAS 90 cubby box inserts ECR For Sale - Parts 1 June 28th, 2010 05:13 PM
Custom Cubby Box for the '97 Center Console For Sale LenB For Sale - Parts 3 January 14th, 2008 04:40 PM
FS - LR OEM Center Console w/radio - 1995 jam90 For Sale - Parts 2 January 19th, 2006 11:31 PM
Center console cubby box PT94D90 For Sale - Parts 1 February 8th, 2004 10:03 PM
Cubby console mount bd90 Defender Technical Discussions 4 December 4th, 2003 01:05 PM
