FS True Xenon HID Kit for Defender - Defender Source
Old November 10th, 2008, 02:59 AM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
I have a complete H4 Xenon headlight kit for sale. This is not the BS Xenon bulbs that just plug in, it is a true HID kit complete with Ballasts etc. Plug and play for H4 headlights, perfect for those of you who have already upgraded to the Hella headlights. These guys are bright! I installed them briefly to test and one bulb appears to be bad (turns on for about 10 seconds then flickers and goes out.) Replacement bulbs are available very cheap on Ebay though. Otherwise, it would be perfect for someone with a motorcyle that uses H4 bulbs, or you could buy two H1 bulbs and install it in a pair of Hella off-road lights!
This is a German made kit, true plug and play, only takes about 1/2 hour to install.
$30 plus shipping. Pictures to follow.
Old November 10th, 2008, 07:38 AM
$30?
Old November 10th, 2008, 07:49 AM
Hammertime's Avatar
Hammertime
Dana Hammersley
1997 Arles Blue #162
I'll take them
Old November 10th, 2008, 10:58 AM
seconds!
Old November 10th, 2008, 11:08 AM
cellulararrest's Avatar
cellulararrest
Chris Snyder
1994 D90 #614 | '07 L322 SC
without projection lenses wouldn't that be absolutely blinding to oncoming traffic?
Old November 10th, 2008, 11:13 AM
I think you should sell them to someone like me, who grew up in Chicago first. :-)
Put me on the list too... I will lick them if it is required.
Old November 10th, 2008, 11:23 AM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
Chris, you don't need projection lens', but the euro Hella lights that many of us have upgraded to have a distinct cutoff pattern like a projection lens' and work great with these. Will go down the order. I pm'd JimC because I didn't know if he wanted them, or was just commenting, but on down the line after that.
Old November 10th, 2008, 02:28 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
JimC has slobbered all over these, but if he changes his mind I'll let you know!
Old November 10th, 2008, 04:27 PM
cellulararrest
Chris Snyder
Any photos or sources to check these out?
Old November 10th, 2008, 05:02 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
Sorry, I already boxed them up for JimC, but I purchased them off Ebay.
Ahh, here is a link.
They really whack you on the shipping though.
Old November 10th, 2008, 06:56 PM
RoverC
Cliff
1997 D90 ST
Actually, there are 2 types of HID bulbs. one for reflectors one for projectors. Sylvania makes a 7" round HID light that is HID low beam (reflector design) and an H3 high beam.
Thats what I have. They are Xenarc headlights.
Now to upgrade the low beam to 55w HID and the same for the high beam!
Old November 10th, 2008, 07:08 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
Well, that kit for the H4 is a xenon low beam and halogen high beam. What I would do is just modify the relay so that the low stays on with the high though because the xenon is so much brighter than the halogen. You can buy a Bi-xenon kit though that is xenon high and low beam. That is what I installed in my 110.
Old November 10th, 2008, 07:13 PM
RoverC
Cliff
1997 D90 ST
actually on the Xenarc lights the low does stay on when the high comes on
Old November 10th, 2008, 07:29 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
Hmm, on a Defender? Because on defender's, the low beam hot wire is turned off when the high beam 12+ is energized. If so, they must have a diode in there somewhere to keep it on. I have this same kit in a 9006 for my j**p and it stays on, but that is because the j**p has a separate high beam bulb and keeps the low beam energized from the factory.
fs, kit
FS Rear Cross Member Fitting Kit & Hella Work Light Stmpede For Sale - Parts 8 June 25th, 2009 12:52 PM
Steel versus Alloy Wheel Bonnet Mounted Spare Kit ronward Defender Technical Discussions 9 October 19th, 2005 01:18 PM
Kenlowe Twin 13" HD Fan Kit Barnett Childress For Sale - Parts 1 September 7th, 2005 04:01 PM
Rovers North 1.5 inch lift kit w/shocks Seriesman For Sale - Parts 1 August 26th, 2005 11:45 PM
NAS SW entire roll bar kit sheki For Sale - Parts 4 September 30th, 2004 05:28 PM
» Defender Registry
B240 SNW
Sandt
110
Mes788
Add your Defender
