August 27th, 2016, 02:40 PM
RBBailey
1965 IIa
FS: ROW Parts
A lot of this will be recycled this week if no one speaks for it in the next day or two. I'll bring it to the ABFM over Labor Day if anyone wants any of it. At this point I will not ship anything. After the ABFM I will ship certain items if you pay. I will post pics, and you can ask for more pics. None of this is in great condition, but some of it is perfectly usable. Everything came off of my LHD Saudi Spec 110 with the 3.5 V8 and factory air like the NAS 110's.
Looking for offers on these as well.
- Saudi/NAS style 110 bulkhead. In bad condition = $60
- V8 Radiator. Was working fine, but had seepage in bottom corner, needs refurb = $40
- Standard bumper, bent, rusty = $1
- V8 fan shroud, dirty, good condition, a few cracks at the mount holes, but not in shroud itself = $60
- Saudi/NAS style wing to heater box fresh air vent ducting. NTC5571 Very dirty. Vacuum thingys probably need replacing, but I don't think there are any cracks in it = $1000 (LOL! Price subject to change... to much lower. I just don't know what to charge for a unicorn.)
- LT85 tunnel cover in good condition = $40
- Tunnel to bulkhead flange fitting piece thingy. Rusted bottoms = $1
- Lower Dash for Saudi/NAS with factory AC. In my opinion, this would be fine as a standard dash if you simply ignored the ducting inside, but it would take a lot of work to refurb for use as it was intended in an NAS 110 = $500
- Rear interior cargo, side window trims, grey. These were cut across the bottom to fit with the tool boxes the previous owner had put in. They are not great, but if you want to put tool boxes in, and don't feel like cutting yours = $40
I think I have some more to add to the list, but need to sort.
Project: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
1965 IIa SWB
August 27th, 2016, 06:55 PM
RBBailey
1965 IIa
1965 IIa SWB
August 27th, 2016, 07:21 PM
Sterling Archer
'08 D3
How are the vent hinges on the bulkhead?
Semper Fi!
August 27th, 2016, 07:56 PM
steve
109/110 ambulance-55 series I
Apparently I'm not the only person looking for those... But his won't have hinges if its a Saudi spec.
August 27th, 2016, 08:07 PM
RBBailey
1965 IIa
None on it. Saudi Spec is almost exactly the same as NAS 110.
1965 IIa SWB
August 27th, 2016, 08:41 PM
Sterling Archer
'08 D3
Duh. Forgot about that!
Semper Fi!
August 28th, 2016, 12:24 AM
RBBailey
1965 IIa
More stuff, make offers:
- Defrost vent tops, both = $10
- Defrost vents, both = $40 (these are the short version, the NAS 110 version was wider)
- Dash top, fair condition, usable, but with cracks as seen in photos = $100
- Duct from filter to turbo for 300Tdi. Seems in good condition, see photos = $60
- Series fuel tank, probably should be inspected and cleaned before use, but there are no rust holes, Por-15 around bottom = $60
- Tunnel cover carpet for the LT85 tunnel listed above, grey = $5
- This thing. Duct from center dash vents to LH side vent in NAS 110. It is nearly perfect like new, but I just could not make it fit! I used a 3" flexible tube instead, like shown at #5, HERE = $5
- PRC3107 fuel gauge = $20
- PRC3108 voltmeter = $20
- PRC3105 water temp = $20
- PRC7320 oil PSI = $60
- LH side sun visor... or use it on the other side and hide the tear... = $10
- Speedo to 150 Km/H = $10
- RHD heater blower; works, but don't know how to say how 'well' it works = $60
- Bulkhead access holes cover thingy, I think I have two of these. Used, but no cracks = $1 ea.
- Locking fuel cap, newer type I believe, threaded, not tabbed. With key. It worked perfectly fine until I pulled the key out, now it does not work because this it's stupid and so that's what would happen, isn't it? = $20 if I can get it working
- Old style metal overflow tank, with bracket, seems in good condition, wasn't leaking = $40
- V8 radiator brace/top = $5
- NAS/Saudi style wide, down-turned pipe heater core. I didn't think it was leaking, but it does look like there are stains on it. = $20
- Defender wiper arms = $5
- 300Tdi bracket for mounting air cleaner to block, incomplete = $5
All photos can be seen HERE, let me know if you want more pics.
1965 IIa SWB
August 28th, 2016, 10:34 AM
John Crouse
I'll take the #15 bulkhead hole cover thingys. How much for the bulkhead vent finishers ( the things that go where the vents should be)? Shown in your pictures.
August 28th, 2016, 04:23 PM
Sam Hagey
1995 RRC LWB - Alpine White
Im putting a lt85 in my current lt77 truck - is your "cover" the sheet metal, or the rubber?
Thanks - Sam
'95 RRC CountyLWB - Swapped to a 4.6L, and now working on a 6.0L LQ4
'83 110 HCPU - in "progess"
'90 RRC Truggy - loud and proud, but mostly ugly
'95 RRC CountyLWB Beluga Black - SOLD
'01 P38 - POS Leaked Electricity - SOLD
August 28th, 2016, 11:41 PM
RBBailey
1965 IIa
The vent blanks are spoken for a long time ago, that's why I didn't actually list them. I'm waiting to hear back from the guy, but you are next in line.
------ Follow up post added August 28th, 2016 09:42 PM ------
Thanks - Sam
It is the thick plastic or fiberglass with padded rubber on the inside. HERE
------ Follow up post added August 28th, 2016 09:45 PM ------
Just so you all know, I'm keeping tabs on who is asking for what first. But as I stated in original post, I'm not going to ship anything till it is unspoken for at the local level. Specifically, I'm carting all of this to the ABFM in PDX next Sunday. Locals to pick up there get first dibs.
Only reason I'm doing that is because it allows me to deal in cash, and is just a lot easier than shipping.
But I will ship to you at your expense if no locals take this stuff by next Sunday evening.
1965 IIa SWB
August 29th, 2016, 08:49 PM
Kris
1985 Tithonus
If you have the fuel gauge after ABFM, I would be interested. Mine is somewhat untrustworthy (POS) and I am not ready to swap everything to VDO yet.
August 30th, 2016, 08:44 AM
Darrell
1987 Defender 90 ex-MOD
Hello, I would be in for the: Dash pad (#3); Volt Meter (#9); Oil Pressure (#11); Overflow tank (#17) and Wiper arms (#20). I will PM you with the address. Would you like the funds via Paypal? Also would you have the two end pieces (Dash Finishers - LHD)?
Thanks again,
Darrell
September 6th, 2016, 10:45 PM
RBBailey
1965 IIa
- PRC3107 fuel gauge = $20 PENDING
- PRC3108 voltmeter = $20 PENDING
- PRC3105 water temp = $20 PENDING
- PRC7320 oil PSI = $60 PENDING
- NAS 110 style bulkhead vent plastic facia covers = $60
This is what I still have. The items in GREEN are spoken for, pending. I have PM'd everyone who posted or PM'd earlier. I will send anything at your expense.
1965 IIa SWB
» Recent Discussions |
