FS: NAS Center Dash Face Plate (milled aluminum) - Defender Source
View Poll Results: What Center Dash Face Plate configs would you like to see?
NAS config (already exists) 1 20.00%
NAS config, but replace the factory "hazard" with Carling hazard 1 20.00%
3x VDO gauge setup 4 80.00%
6x Carling Switch setup 1 20.00%
2x 12v & 4x Carling Switch (config as 12v-C-C-C-C-12v) 3 60.00%
Multiple Choice Poll. Voters: 5. You may not vote on this poll
Old February 24th, 2014, 11:51 AM
Thumbs up FS: NAS Center Dash Face Plate (milled aluminum)
Just wrapped up the latest project, the NAS Center Dash Face Plate for any year Land Rover Defender NAS 90 (note: this is a NAS-only specific configuration).
This is an upgraded replacement for the center face plate in the NAS 90's which houses the hazard switch, clock, and 12v cigar lighter (or the factory 12v is easily replaced with a Blue Sea 12v or dual USB as the cutout size will accept either). The factory face plate is basically a piece of very thin metal wrapped in vinyl, and over time these tend to bend or become warped (not to mention look unsightly). This new Center Dash Face Plate uses a pressure fit to keep the hazard, clock, and 12v firmly in place.
This dash center plate panel offered here is a great upgrade, and not only dresses up your NAS Defender but is exceptionally more durable than the factory face plate. Milled from 1/4" thick solid CNC milled aluminum and powdercoated in satin/semigloss black, they are guaranteed to withstand the test of time, elements, and whatever you can throw at your Land Rover. For the D-90 folks here (pretty much offering it just to this crowd) it will come with new mounting stainless screws/hardware (2 machine screws & 2 nuts).
$85 + shipping (see below for 10% discount, and shipping is ~$6 for a single unit conus) for (1) NAS Center Dash Face Plate that is powdercoated black and includes stainless mounting hardware.
PayPal or Credit Cards accepted, and can be ordered here: https://www.seriesdefender.com/face/...ter-panel.html
PLEASE NOTE: there is a 10% discount to D-90 members, just use the coupon code "D90" at checkout and it will automatically be applied to your entire order.
INTERNATIONAL SHIPPING: we are also shipping to the UK and Canada, simply input your address information and the international shipping will automatically be calculated for you.
Ready for immediate shipping!
ID:	90257   Click image for larger version
ID:	90259   Click image for larger version
ID:	90261   Click image for larger version
ID:	90263   Click image for larger version
ID:	90265   Click image for larger version
ID:	90267   Click image for larger version
ID:	90269   Click image for larger version
ID:	90271   Click image for larger version
ID:	90273   Click image for larger version
ID:	90275   Click image for larger version
ID:	90277   Click image for larger version
Old February 24th, 2014, 12:31 PM
Very nice. Any chance of getting you to do one for three round gauges ?
Old February 24th, 2014, 12:38 PM
solarguy's Avatar
solarguy
Abraham Bell
1985 Defender 110 Tithonus
Very nice. I am with Doug. Any chance?
Old February 24th, 2014, 01:00 PM
Roverenvy's Avatar
Roverenvy
Michael
1994 Defender 90
Not a bad idea! More....NEW VDO gauges!!
Old February 24th, 2014, 05:26 PM
UnfrozenCaveman's Avatar
UnfrozenCaveman
Keith Armstrong
Various
I'd be in if a VDO oil pressure gauge will fit in there.
Preferably in place of the lighter...
Old February 24th, 2014, 07:04 PM
I've got a list of "other" configs that I'm considering, and the 3x VDO was initially on that list - but it seemed like it was going to be a bit tight to fit them in (with very little material left on the perimeter at the outer edges). But I'll take a look at this again and possibly put it up for contention if there's enough interest.
Old February 24th, 2014, 07:25 PM
yours would be mo-betta
http://www.croytec.co.uk/products/images/DSCF0032a.JPG
http://www.defendersource.com/forum/...7&d=1212284350
Old February 24th, 2014, 08:17 PM
Abrooks's Avatar
Abrooks
Tony Brooks
Great work!!
Old February 24th, 2014, 09:01 PM
James Pierce's Avatar
James Pierce
James Pierce Jr.
Nice. I might also suggest textured Powder coating. It would look a little closer to the original. However if no one else likes the idea I'd take one bare and have it done on my end.
Old February 25th, 2014, 01:03 AM
Interesting, that's the first I've seen those setups so it's obvious it can be done...I'll revisit and put it on the possibilities list. I'm assuming the interest would be for VDO only? I'm speaking dimensionally here, though I believe the factory gauges are the same/similar measurements.
Old February 26th, 2014, 06:45 PM
Yes please- most aftermarket gauges utilize the same diameter hole that the stock gauges do. Croytec only makes these to special request. Yours look to be far better anyway.
Old February 26th, 2014, 07:12 PM
Should be able to make this happen, though admittedly may take a little while.
Stupid question - is there only 1 size of VDO gauge? In other words it's not like they have a "newer" version that may be dimensionally different than older VDOs?
Old February 26th, 2014, 08:42 PM
James Pierce
James Pierce Jr.
The majority of aftermarket gauges fit into a 2 1/16" hole including VDO. The difference may be if you recess the bezel like the ones shown above.
Old February 27th, 2014, 10:25 AM
Apparently my temp gauge has been subscribed to this thread, since as of this weekend I noticed it was "intermittent" and as of this morning it's pretty much shot and not reading. Going to trouble shoot any loose wires/grounds (as it did bounce back when I took a turn coming back home), but may use this as an excuse to move over to a VDO temp gauge anyhow since the factory gauge is notoriously inaccurate. So I may have one to measure off of .
Quick poll - would folks rather have the recessed bezel or just mount the VDOs so they stick out as shown below? My main concern is that things will start to get real "thin" in there with a recessed bezel into the face plate.
Old February 27th, 2014, 11:10 AM
no need to countersink
Old February 27th, 2014, 11:41 AM
Roverenvy's Avatar
Roverenvy
Michael
1994 Defender 90
I second. Durability first! No need to be flush if it makes it too thin.
Old February 27th, 2014, 11:58 AM
solarguy's Avatar
solarguy
Abraham Bell
X2. It will be very nice.
Old March 24th, 2014, 09:09 PM
So who's in for a 3x VDO version of this dash center plate? If we've got enough interest I think we can make this happen.
Old March 25th, 2014, 07:04 AM
Roverenvy's Avatar
Roverenvy
Michael
1994 Defender 90
I think I would be. I need to check with David on my rebuild, it's on our list to discuss. (trucks pulled apart as we speak.)
Old April 8th, 2014, 10:23 PM
Alright, so I'm toying with some other configurations as follows...I know we had a few interested in the 3x VDO config, but would like to get some hard numbers on that first. So essentially the other configs I'm tossing around are as follows:
- 3x VDO Gauges
- 6x Carling Switches
- 2x 12v & 4x Carling Switches (which would essentially be setup as 12v-carling-carling-carling-carling-12v)
Thoughts/input? Other requests? I actually did a poll above, please vote for the configurations you'd like to see (you can choose more than one as I plan to hopefully spin out a few alternate versions based on demand).
I think Roverenvy, Uncle Douglas, solarguy, and UnfrozenCaveman were initially interested in the (3) VDO setup. Is that still the case?
ac, aluminum, dash, fs, nas
LHD Dash CDeWan For Sale - Parts 32 October 3rd, 2012 05:03 PM
Defender NAS 110 dash help needed ROVERMAN1 Defender Technical Discussions 5 September 8th, 2012 11:50 AM
Center Dash Fascia Plate Miller Wanted 8 August 4th, 2012 10:49 AM
NAS 90 Aluminum Fuel Tank Cradle back in stock $169.99 SafariHP The Vendors Loft 1 April 17th, 2012 11:09 AM
FS: 90 center dash with working clock ECR For Sale - Parts 2 November 4th, 2011 10:50 AM
