FS Lots of Defender Stuff! - Defender Source
Old November 10th, 2008, 02:17 AM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
RF matte eyebrow (JimC has first shot at this one as per a previous discussion) $100
Upper OEM Swingaway Tire Carrier Bracket/Hinge (NIB, RN gets $133.18 for this) $100
D90 Stainless Chassis Bolt Set (Brand New, includes tub to cross-member kit) $50
Carpet Frt. Floor Mats (fleabus has first shot at these) $30
-Rt. one is in great shape, Left is good, but the edging is coming apart, includes additional sound
deadening that is installed underneath.
Rubber Frt. Floor Mats $20
-Some damage to the edges, but certainly beats $90 for new ones
Single Driver Side heavy rubber insulated floor mat -$10
-Very Good Condition
5-bar front floor panels $150
-Painted with black truck bedliner to give more grip. Some chips in the bedliner near the edges, but
can either be stripped off to bare aluminum or touched up with a can from NAPA
OEM D110 Interior Dome Light (Brand New in Box, RN gets $88.34 for this) $50
Chevy Dome/Map Light (I had planned to mount this in my 110 but changed my mind) $15
Chrysler Dome Light (Same idea as above) $10
5.25" speaker spacers (Creates additional clearance for speaker magnets, NIB) $10
Orig. Center Console from my 110 (Includes OEM Radio in unknown but believe working cond.) $75
-Not perfect, but pretty good shape, certainly far better than the majority out there
D110 OEM Amp for radio (Same cond. as above) $25
OEM Bumper & POE 110 Winch Mount Bracket $400
-Bumper has not been installed since it was repainted (no turn signal style bumper)
-Bracket was also stripped and repainted, has also been modified to accept X9 Superwinch, but orig
designed to mount a WARN 8000
Taylor 8mm plug wires $25
-Installed for about 5 miles, perfect cond. coil wire included, but does not fit stock setup)
Cap & Rotor (Napa, not the junk LR one) $35
-Installed for about 5 miles, perfect cond. Cost app. $60+ at NAPA
Right side Headlamp Finisher (NIB, RN gets $44.25 for this) $25
D90 OEM Galvanized Rocker Panels (C channel, not the sills, NIB) $150 for the pair
Rear Corner bracket for tub (Series & Defender, Galvanized) $2
Rear License plate light spacer (NIB) $5
OEM D110 Auto Dimming Rearview Mirror $40
-Includes long pigtail with proper connector and orig. wire shield to hide the wire coming down from the
headliner.
American Dirt Roads Light Panel that fits in the dash recess where the clock is in a D90 (Custom made for me by Len) $30
-Has mounting holes to fit two factory cigarette lighters (also included), heated seat switches, and
rocker switch to turn light on and off (included).
Factory D110 Springs -$100
-Good condition, truck was not sagging or anything, just replaced to go to OME HD's
Thats all for now. haha. Pictures to follow tomorrow. Prices do not include shipping.
Lick away folks!
Old November 10th, 2008, 07:40 AM
Yeah, I'll take that fender flare.
Old November 10th, 2008, 08:24 AM
JRW's Avatar
JRW
94 D90 ST #1247
Andrew,
I'll take the following:
Single Driver Side heavy rubber insulated floor mat -$10 (If it will fit a D90)
Rear License plate light spacer (NIB) $5 (If it will fit a D90)
Please confirm those last two will fit a 90. Shipping will be to 75022.
Thanks!
Old November 10th, 2008, 08:26 AM
tomaco1's Avatar
tomaco1
T.mac
83 110
Intersted in both
I'll take spacers if there are for the dash
light panel pending pics
Old November 10th, 2008, 09:57 AM
GYM's Avatar
GYM
Gary
97 SW
2nd in line for the single driver side heavy rubber insulated floor mat...
Old November 10th, 2008, 10:31 AM
fleabus's Avatar
fleabus
Dan
None :(
I'll take the carpeted floor mats... PM sent.
-Dan
Old November 10th, 2008, 10:48 AM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
Jim - Same deal as last time? If so, shoot it to me in a PM again, I think I deleted the one with your address and Fedex info.
John - Yes, both will fit a D90. In fact, I believe the mat came from a 90.
Tom - I'm not sure if the spacers fit a D90 dash or not. I bought them for the dash on my 110 to clear the heater flap, but then realized the dash speakers in my truck are only 4". These will fit the back, door if you mount speakers there, or possibly your dash, but I can't say. You'll have to measure your speaker. Pics are on the way!
Old November 10th, 2008, 11:17 AM
I will take the Auto Dimming mirror.
Old November 10th, 2008, 11:57 AM
rayfi's Avatar
rayfi
Derek Moeller
110
What rear corner bracket do you have? NAS? Please sens a picture dmoeller@marseefoods.com
Old November 10th, 2008, 12:11 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
You changed pic sizes on me again...You're killin' me smalls!
Console also includes a new striker for the latch (not pictured) Latch and key should be swapped from your old one. The lock barrel is missing from this latch.
Rubber mat has a small crack (about 1") right where it bends to go up the firewall. I couldn't see it orig. because it sort of disappears when the mat is in its normal shape, only shows up when it is laying completely flat, but still overall pretty good shape for $10.
Carpet mats and 5 Bar both show some dust spots in the pic (in the air between the camera and the item that the flash picked up but are just in the pics). Carpet needs to be vacuumed but is in good shape otherwise.
ID:	16220   Click image for larger version
ID:	16222   Click image for larger version
ID:	16224   Click image for larger version
ID:	16226   Click image for larger version
ID:	16228   Click image for larger version
ID:	16230   Click image for larger version
Old November 10th, 2008, 12:26 PM
NashvilleRover's Avatar
NashvilleRover
Dendy Jarrett
2009 LR3- Well Built
OEM 110 Dome light licked and paid for!
Dendy
Old November 10th, 2008, 03:11 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
Oops, sorry this one didn't upload the first time, here it is though...
Old November 10th, 2008, 03:24 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
Dirt Road picture?
Old November 11th, 2008, 07:03 AM
BEIS's Avatar
BEIS
RYAN BEIS
D110 Soft Top with full rollcage
Can you put up a picture of the OEM Bumper & POE 110 Winch Mount Bracket ? Thanks buddy.
-Ryan
Old November 11th, 2008, 08:50 AM
galen216's Avatar
galen216
Galen Lentz
'98 D1
What is the part # on the NAPA cap and rotor? I assume it is the same for an '94 RRC, if so I'll take it.
'98 D1
Old November 11th, 2008, 12:25 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
Ryan, Pics coming, camera is charging as we speak.
Galen, EP71(rotor) and EP78(cap)
Here are the pics of the bumper and winch mount. The white on the bumper is just dust.
ID:	16243   Click image for larger version
Old November 11th, 2008, 07:40 PM
vesparover's Avatar
vesparover
brian bertolini
I'll take the thingh len made you- take paypal?
brian bertolini
deweyberts@yahoo.com
Old November 12th, 2008, 06:35 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
RF matte eyebrow (JimC has first shot at this one as per a previous discussion) $100 SOLD
D90 Stainless Chassis Bolt Set (Brand New, includes tub to cross-member kit) $50 SOLD
Carpet Frt. Floor Mats (fleabus has first shot at these) $30 SOLD
Single Driver Side heavy rubber insulated floor mat -$10 SOLD
OEM D110 Interior Dome Light (Brand New in Box, RN gets $88.34 for this) $50 SOLD
Rear License plate light spacer (NIB) $5 SOLD
OEM D110 Auto Dimming Rearview Mirror $40 SOLD
headliner.
Forgot to mention, everything that has been paid for was shipped today, so you should all receive your new treasures within a few days!
Old November 12th, 2008, 07:14 PM
vesparover's Avatar
vesparover
brian bertolini
Hi, is there a line for the american dirtroads part?
I'll paypal you now.
Old November 12th, 2008, 07:57 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
Yeah, you are second. I need to get a picture for Tom, but my camera is acting up, if it doesn't start syncing with my computer soon I am going to borrow a friend's when he gets home.
fs
Garage Sale: Disco And Defender Stuff ember For Sale - Parts 5 October 4th, 2005 12:24 PM
1991 RRC FS. Lots of New Parts. Mike M For Sale - Vehicles 4 February 14th, 2005 08:16 PM
lots of stuff for sale jperakis For Sale - Parts 48 December 27th, 2004 11:13 AM
FS: 1995 Beluga Black Defender mpodgorski Misc. Chit-Chat 9 May 23rd, 2004 02:45 PM
Maybe FS: 1999 Defender 110 Td5 mlepisto For Sale - Vehicles 3 March 18th, 2004 02:17 PM
