FS in NV - 3.9, trans, xfer and tdi parts - Defender Source
Old January 20th, 2016, 06:14 PM
Broncoduecer's Avatar
Broncoduecer
peter
D90
Some items for sale from my tdi swap, all shipped unless otherwise stated:
Randoms:
AMR3386 mechanical speed sensor 1994 NAS 90 - $40
MUC4299 New Series rubber vent seals, pair - $25 for the pair
AMR6525 genuine NLA, NIB, NAS top Amber lenses 95+ - $40 each
AMR3850 NIB, 95+ lower lamp plinth (2) - $5 each
ESR2847 rad shroud 94-99 disco, 95 RRC - $45
From my 1994 NAS Defender 90, 3.9L:
Radiator, recored less than 1k miles ago - $400
V8 fan shroud - $100
SS trailhead oil cooler lines, used, 3k miles, - $170
V8 radiator support brackets - $60
Alternator - $75
Transmission crossmember - $50 + shipping
ECU and engine harness from 1994 Defender, AMR3606 & ERR4943, 3.9L, only cut was terminal for VDO water temp - $1000
Other TDi parts:
300tdi Defender radiator support brackets - $45
300tdi disco radiator support/frame - $75
300tdi fan and fan clutch - $45
300tdi coolant reservoir w/cap - $25
300tdi power steering pump - $70
300tdi transmisson crossmember - $50 + shipping
These are all bulky and pickup or meetup would be preferred:
LT230 from my 1994 Defender, 120k, worked fine. - $100 + shipping
ZF4HP22 that was in my Defender, but came out of a disco, mileage unknown, shifted fine when pulled but don't know much about it's life - $50 + shipping
3.9L from my 1994 Defender, 120k, no engine harness, getting a little tired, middle cylinders >10% from the rest of the cylinders - $100 + shipping (or come get it and it's a 12 pack)
Simbars brush guard (good shape, some rust/paint peel on inside of guards) - $80 + shipping
some pics here from my last attempt to sell:
http://www.defendersource.com/forum/...-nv-52575.html
FYI - I can only get stuff out on the weekends.
Old January 20th, 2016, 06:27 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
PM,ed about LT230
licked for the time being
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old January 20th, 2016, 07:01 PM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
Can I get a shipping quote for the brush guard to Oregon 97850?
We have a Fastenal in town.
Current fleet: '85 Ninety 3.9 V8i Auto SW, two Discovery 1's (one for my Nephew, one for my Niece),'07 BMW 335Xi.
Old January 20th, 2016, 07:15 PM
What's the condition of the fan/fan clutch? And the coolant reservoir? Also is the reservoir the white-ish or the black reservoir?
Will also take the MUC4299 if they are genuine (and probably even if they're not : ).
Licked pending answers.
Old January 20th, 2016, 07:23 PM
slorocco
Dan Prasada-Rao
1963, 109 Station Wagon
I'd be interested in the stainless oil cooler lines, the series vent seals and the 94 "rear crossmember". Can't you confirm exactly what the cross member is? What I'm wanting is the crossmember that goes under the trans/case for a 94 with v8/lt77.
Old January 20th, 2016, 08:41 PM
Broncoduecer
peter
D90
I'll go get some measurements and a weight and get back with you.
Fan and clutch look in alright shape, never ran them, I went straight to new to go with the them of the swap. Pics can be seen in the link for fan and reservoir. It's the black one. Little dirty inside but looks solid. Comes with cap. Also never ran the tank, just went right to new. And seals aren't genuine unfortunately.
Sorry I meant to say transmission crossmember so this is the one you want. I fixed that in the descriptions. Seals will go to Nathan first, but if he passes you're next.
Old January 20th, 2016, 09:42 PM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
Mounting hardware included with brush guard?
Old January 20th, 2016, 10:05 PM
Broncoduecer
peter
D90
It's made to work with the stock bumper and bolts. Additionally there are two straps the mount the bottom of the bumper to the bolts of the tow point things on the frame. After 4 years I actually still have them!
Old January 20th, 2016, 10:47 PM
Broncoduecer
peter
D90
Also have:
300tdi discovery tube turbo to air box - $45
more from my 1994 NAS defender 90, 3.9L:
Fan and newer clutch (<3k miles) - $55
Intake tube, filter housing to intake - $60
Air filter housing and horn - $50
MAF - $45 (have 2)
Coolant expansion tank - $35
Rad and heater hose set, used low miles - cover shipping
Plug wire set, used low miles - cover shipping
EVAP system, front canister, rear canister/box by tank, and line to front - $120 (little concerned about bending the tube that goes from rear to front)
Old January 20th, 2016, 11:11 PM
slorocco
Dan Prasada-Rao
Cool, I'll take the cross member and SS cooler lines as well as the intake tube, could you pm me your PayPal info and a total including shipping to 20634
Old January 21st, 2016, 12:22 AM
KSARover110's Avatar
KSARover110
Dan
1983 Rover 110
Also have: 300tdi discovery tube turbo to air box - $45 more from my 1994 NAS defender 90, 3.9L: Fan and newer clutch (<3k miles) - $55 Intake tube, filter housing to intake - $60 Air filter housing and horn - $50 MAF - $45 (have 2) Coolant expansion tank - $35 Rad and heater hose set, used low miles - cover shipping Plug wire set, used low miles - cover shipping EVAP system, front canister, rear canister/box by tank, and line to front - $120 (little concerned about bending the tube that goes from rear to front)
I'll take the fan and newer clutch. PM me PayPal info pls
Old January 21st, 2016, 12:30 AM
E36 Phantom
Chad
94 RRC SWB
Interested in the transmission and engine. Where in NV are you?
Old January 21st, 2016, 01:01 AM
One Ten's Avatar
One Ten
Sam
1994 NAS SW
I'll take AMR3850 x2
Old January 21st, 2016, 09:00 AM
Broncoduecer
peter
D90
All located in Elko, NV 89801.
Old January 21st, 2016, 12:58 PM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
Shipping on the brush guard is way high so I am out. Sorry.
Old January 21st, 2016, 01:05 PM
I'll take the 300 tdi trans crossmember
Old January 21st, 2016, 01:27 PM
Broncoduecer
peter
D90
No worries.
Sorry Doug, this one is gone already.
Your in Reno as I recall. Ill take theLT230 if its not spoken for. I can probably come this weekend if its not snowing.
-Jeff
Still waiting to see if the shipping quote works out for John. I'm actually in Elko, so add another 4 hours to that.
Old January 21st, 2016, 01:39 PM
Broncoduecer
peter
D90
Update:
Randoms:
pending MUC4299 New Series rubber vent seals, pair - $25 for the pair
pending AMR3850 NIB, 95+ lower lamp plinth (2) - $5 each
pending SS trailhead oil cooler lines, used, 3k miles, - $170
Alternator - $50
pending Transmission crossmember - $50 + shipping
sold Fan and newer clutch (<3k miles) - $55
pending Intake tube, filter housing to intake - $60
MAF - $45 (have 2)
Other used TDi parts:
pending 300tdi fan and fan clutch - $45
300tdi power steering pump - $50
sold 300tdi transmission crossmember - $50 + shipping
pending LT230 from my 1994 Defender, 120k, worked fine. - $100 + shipping
pending ZF4HP22 that was in my Defender, but came out of a disco, mileage unknown, shifted fine when pulled but don't know much about it's life - $50 + shipping
pending 3.9L from my 1994 Defender, 120k, no engine harness, getting a little tired, middle cylinders >10% from the rest of the cylinders - $100 + shipping (or come get it and it's a 12 pack)
Old January 21st, 2016, 01:51 PM
east high's Avatar
east high
Gerad Davis
1967/s2a 88 200Tdi
I'll take the alternator provided it's the 65 amp and the connections are posts like this:
Old January 21st, 2016, 08:51 PM
Broncoduecer
peter
D90
Looks like this:
No real numbers on it. 00366114?
fs, part, parts, tdi
LT77 Transmission and 1.6 Xfer Case For Sale javelinadave For Sale - Parts 5 January 3rd, 2016 12:11 PM
WTB: D1 Transmission and Xfer Case PCRover Wanted 9 March 14th, 2008 11:11 PM
'95 Disco trans/xfer for trade boxerhips For Sale - Parts 3 January 4th, 2005 11:47 PM
EMERGENCY-Xfer case issues Cyborg Defender Technical Discussions 7 July 18th, 2004 02:50 AM
97 trans/xfer into 95 Disco boxerhips Defender Technical Discussions 4 June 10th, 2004 01:08 AM
» Defender Registry
Ninety
Paul K
Big Bird
owen
Add your Defender
