FS Glow Plug Relay, Heavy Duty Controller - Diesel - Defender Source
Old April 8th, 2015, 06:35 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Heavy Duty Automatic Glow Plug Controller with built in timer.
We use these with great success on Diesel Engine Conversions.
Turn on the key and the glow plugs run for 12 to 14 seconds.
Has a lead for a dash light and one which ends the glow cycle when the starter is engaged.
Rated @ 70 AMPs and about 4 times larger than the little relays that have small contacts and windings.
$69 + $11 flat rate shipping.
Legend for third picture:
30 - Power from battery (+) source (usually power lead on starter solenoid)
87 - Up to 6 Glow Plugs (+)
86 - Switching source (+) (ignition or fuel shutoff solenoid on injection pump)*
85 - Ground (-)
L - To Dash Warning Light (+)
50 - To starter engagement lead on starter solenoid (+)
ID:	117905   Click image for larger version
RDavisinVA
Old April 9th, 2015, 08:08 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
RDavisinVA
Old April 13th, 2015, 07:58 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Only 3 available.
RDavisinVA
Old April 14th, 2015, 10:05 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
1 Available.
RDavisinVA
Old April 15th, 2015, 01:13 AM
Fearnofish's Avatar
Fearnofish
85 110 CSW
So this is better than the stock setup? Worth replacing a working unit? Thanks.
Old April 15th, 2015, 05:26 AM
red64chevelle
Daniel Smith
86 110 300TDI,96 D1 5speed,08 RRS
PM sent
75% of all Land Rovers ever made are still on the road...
the other 25% at least made it home.
Old April 15th, 2015, 05:53 AM
BlackField's Avatar
BlackField
Oscar
D110
I'll take it
Old April 15th, 2015, 06:22 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
I have replaced at least a half dozen of these on 200TDI setups, which have a tendency to burn the contacts shut making the glow stay on until they burn out.
I think these relays were rated at 40 AMPS.
The 300TDI went up to 50 amps, so the problem is much less common than with a 200TDI.
This relay is rated @ 70 amps and I've used them for years.
When members started asking about this because of a thread I posted, started supplying them.
Next thing I knew people started using them on diesel conversions.
I don't know if you need to replace your relay until it goes bad, but if it does by the time you disconnect the battery or relay, the glow plugs will have burned out and the cost of new ones and the trouble to replace them is less than installing this heavy duty unit and finding a stock replacement.
So if you subscribe to the adage "anything worth doing is worth overdoing" to prevent a failure, I think it's a good choice.
RDavisinVA
Old April 15th, 2015, 08:09 AM
Fearnofish's Avatar
Fearnofish
85 110 CSW
Ok well done sir. I will take one. Good thing your not selling kitchen remodels to my wife! I'd be eating out for a year......😄
Old April 15th, 2015, 08:15 AM
Robert The Davis,
Will a 300 tdi wiring harness plug right up to this timer/relay ?
Worldwide Land Rover Shipment and Importation Service
Bespoke Restoration & Modification work
Old April 15th, 2015, 06:53 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Robert The Davis,
This relay is heavy duty, so the 2 main power leads are bolt on instead of spade connector, so some adapting will need to take place to replace the spades with screw down round lug eye connectors.
Ok well done sir. I will take one. Good thing your not selling kitchen remodels to my wife! I'd be eating out for a year......��
Will ship out tomorrow.
We are sold out.
Will try and get a few more next week, but not sure I can.
Cleaned them out of USA stock.
Anyone needing one PM me and will put you on the waiting list which is 2 deep at the moment.
RDavisinVA
Old April 25th, 2015, 03:12 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
1 Available.
RDavisinVA
Old April 28th, 2015, 05:56 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Last one.
RDavisinVA
Old April 28th, 2015, 06:35 PM
So does the starter lead (50) energize the starter? Or does it do something to turn off the relay when the starter is engaged?
Old April 28th, 2015, 07:33 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
50 auto-magically switches off power to the glow plugs.
RDavisinVA
Old April 28th, 2015, 10:28 PM
Thanks I'll put one of these relays on my want list for next winter.
Old April 30th, 2015, 06:23 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
They are hard to get and right now we have 1 extra as I need 1 for the Iveco conversion.
1 available if anyone needs it.
RDavisinVA
Old April 30th, 2015, 07:24 PM
fishy69
Matt Fisher
1987 110
I'll take it.
Old June 5th, 2015, 07:38 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
RDavisinVA
Old June 6th, 2015, 06:24 PM
icnsltmfg's Avatar
icnsltmfg
1988 D90 RHD 19J
It was an easy install and works flawlessly...allowed me to install a new style ignition switch (same key as the doors) but does not have a glow terminal...with a 19J there was never a timer...thanks Robert!
America Runs on Dunkin'
Rovers Run on Diesel
2017 Range Rover L405 HSE TD6 on order
2008 Range Rover HSE L322/MkIII
1988 D90 County RHD 2.5TD
2015 Porsche Cayenne TD
diesel, fs, relay
Glow plug timer relay o2batsea Wanted 0 June 24th, 2013 06:20 AM
Glow Plug Relay and Wiring Ren Ching Wanted 0 January 21st, 2010 12:27 PM
Pin-out for the PRC 6913 glow plug relay? dmarchand Defender Technical Discussions 7 July 10th, 2007 04:51 PM
Glow Plug Relay Michael Defender Technical Discussions 1 March 16th, 2006 01:28 PM
LR Glow Plug relay temp? dmarchand Defender Technical Discussions 0 June 9th, 2004 12:42 PM
