FS Glow Plug Relay, Heavy Duty Controller - Diesel - Page 2 - Defender Source
Old June 7th, 2015, 08:15 AM
rdavisinva's Avatar
rdavisinva
Guess Who?
N/A
Originally Posted by icnsltmfg View Post
It was an easy install and works flawlessly...allowed me to install a new style ignition switch (same key as the doors) but does not have a glow terminal...with a 19J there was never a timer...thanks Robert!
I use these things on every engine conversion regardless because the small cheap OEM relays fail and this one has longevity.
The older style switches eventually fail because the 40 AMP glow plug load goes through the contacts in the switch and eventually they heat up and burn out.
Also when the points get partially burnt, not all the (+) current will flow through and the glow plugs get a weaker power supply and create hard starting.
$69 + $11 flat rate shipping.
RDavisinVA
Old July 31st, 2015, 10:14 AM
rdavisinva's Avatar
rdavisinva
Guess Who?
N/A
1 Available.
RDavisinVA
Old August 1st, 2015, 11:50 AM
rdavisinva's Avatar
rdavisinva
Guess Who?
N/A
1 Available.
RDavisinVA
Old August 15th, 2015, 11:49 AM
rdavisinva's Avatar
rdavisinva
Guess Who?
N/A
1 Available.
RDavisinVA
Old October 11th, 2015, 02:49 PM
rdavisinva's Avatar
rdavisinva
Guess Who?
N/A
$69 + shipping or free delivery to Uwharrie.
RDavisinVA
Old October 22nd, 2015, 08:50 AM
rdavisinva's Avatar
rdavisinva
Guess Who?
N/A
Originally Posted by Fearnofish View Post
So this is better than the stock setup? Worth replacing a working unit? Thanks.
For some reason the stock units stick and when they do the glow plugs all burn out.
I use this setup on all my diesel conversions.
RDavisinVA
Old October 25th, 2015, 08:56 AM
rdavisinva's Avatar
rdavisinva
Guess Who?
N/A
RDavisinVA
Old October 25th, 2015, 11:25 PM
John O from Jersey
John O'Marra
1970 Series IIA
PM sent
Old October 26th, 2015, 08:59 AM
rdavisinva's Avatar
rdavisinva
Guess Who?
N/A
John, you actually sent an email.
I replied...
RDavisinVA
Old November 11th, 2015, 07:44 AM
rdavisinva's Avatar
rdavisinva
Guess Who?
N/A
RDavisinVA
Old December 15th, 2015, 10:11 PM
rdavisinva's Avatar
rdavisinva
Guess Who?
N/A
RDavisinVA
Old December 16th, 2015, 02:44 PM
rdavisinva's Avatar
rdavisinva
Guess Who?
N/A
RDavisinVA
Old December 16th, 2015, 10:18 PM
rdavisinva's Avatar
rdavisinva
Guess Who?
N/A
Heavy Duty Automatic Glow Plug Controller with built in timer.
We use these with great success on Diesel Engine Conversions.
Turn on the key and the glow plugs run for 12 to 14 seconds.
Has a lead for a dash light and one which ends the glow cycle when the starter is engaged.
Rated @ 70 AMPs and about 4 times larger than the little relays that have small contacts and windings.
Legend for third picture:
30 - Power from battery (+) source (usually power lead on starter solenoid)
87 - Up to 6 Glow Plugs (+)
86 - Switching source (+) (ignition or fuel shutoff solenoid on injection pump)*
85 - Ground (-)
L - To Dash Warning Light (+)
50 - To starter engagement lead on starter solenoid (+)
RDavisinVA
Old January 1st, 2016, 10:39 AM
rdavisinva's Avatar
rdavisinva
Guess Who?
N/A
$59.00 + $13 shipping
RDavisinVA
Old January 4th, 2016, 08:58 AM
rdavisinva's Avatar
rdavisinva
Guess Who?
N/A
RDavisinVA
Old January 4th, 2016, 09:56 AM
tomaco1's Avatar
tomaco1
T.mac
83 110
ill take it
Old January 14th, 2016, 09:38 AM
rdavisinva's Avatar
rdavisinva
Guess Who?
N/A
Shipped.
$69 + $11 flat rate shipping if anyone else needs one.
RDavisinVA
Old January 18th, 2016, 11:27 AM
rdavisinva's Avatar
rdavisinva
Guess Who?
N/A
RDavisinVA
Old January 28th, 2016, 12:10 PM
rdavisinva's Avatar
rdavisinva
Guess Who?
N/A
RDavisinVA
Old February 2nd, 2016, 03:38 PM
rdavisinva's Avatar
rdavisinva
Guess Who?
N/A
RDavisinVA
diesel, fs, relay
Glow plug timer relay o2batsea Wanted 0 June 24th, 2013 06:20 AM
Glow Plug Relay and Wiring Ren Ching Wanted 0 January 21st, 2010 12:27 PM
Pin-out for the PRC 6913 glow plug relay? dmarchand Defender Technical Discussions 7 July 10th, 2007 04:51 PM
Glow Plug Relay Michael Defender Technical Discussions 1 March 16th, 2006 01:28 PM
LR Glow Plug relay temp? dmarchand Defender Technical Discussions 0 June 9th, 2004 12:42 PM
