FS: Everything from a 2.25L Petrol except the block - Defender Source
Old February 24th, 2014, 06:07 PM
Linoge's Avatar
Linoge
Jonathan
1985 D90
I am not even going to try to go through each individual part and list and price them, so here is the deal - the 2.25L petrol out of my '85 D90 decided to connect cylinders 3 and 4 by way of a channel cut in the top of the engine block. Everything else on the engine appears to be perfectly fine and in perfect working order, including even the head itself (with the obvious exclusion of the head gasket). If you need something for a 2.25L engine, I probably have it.
The engine had about 154,000 miles on it when it died, so you can figure all of the parts / ancillaries / etc. are about as old.
Contact me for availabilities, shipping is on the buyer, pick-up / RURR is preferred.
As for the block itself, I figure it will make a nice end table. Or I might take it out to a range to perform some penetration testing on it. *shrug*
Old February 25th, 2014, 09:12 AM
Linoge's Avatar
Linoge
Jonathan
1985 D90
For clarification, I would be willing to sell the block, but this is what you will be up against:
Old February 25th, 2014, 11:32 AM
broadstone's Avatar
broadstone
'84 CSW 90 '74 NADA III '97 CSW 110
Did it have power steering? If so possibly interested in the pump bracket (ERC6974). Thanks.
Old February 25th, 2014, 05:47 PM
Linoge's Avatar
Linoge
Jonathan
1985 D90
Yup, had power steering.
Old February 25th, 2014, 05:50 PM
It is definitely not a 2.5l Petrol? You would think a 1985 would have a 2.5.
Old February 25th, 2014, 05:58 PM
Linoge's Avatar
Linoge
Jonathan
1985 D90
The VIN is SALLDVAH7AA######.
According to this decoder, that lines up to a 2.25L petrol or 2.5L V6. It is definitely not a V6.
Regarding the date of manufacture, according to the letter I have from the British Motor Industry Heritage Trust, it was assembled on 11APR85.
Old February 25th, 2014, 06:20 PM
Reading "the book", it says the change did not happen until August 1985. There you go.
Old February 25th, 2014, 06:27 PM
South African Land Rovers had a 2.6 liter straight six version of the E series engine. Lets just say the E series was not one of British Leyland's finest attempts at engineering. Horrid in 4 cylinder (1485cc/1748cc), not much better as a six (2227cc/2622cc).
I should know my Dad had a one of both......
Old February 25th, 2014, 06:38 PM
Bigdoh's Avatar
Bigdoh
94 D90 #1642
Ahh, thanks for the link to the decoder. Now I am concerned as my vin number on a recently purchased 94 d90 doesn't follow the decoder? What to do next....scratching head
And a little digging got the right info, it's a Cali spec model. Now to find what that means.
Old February 26th, 2014, 02:29 AM
broadstone's Avatar
broadstone
Sent you a PM. Let me know what you would be asking for the pump bracket.
Old February 26th, 2014, 09:12 AM
phoenix37's Avatar
phoenix37
john
whats it have for a carb?
Old February 26th, 2014, 10:36 AM
Linoge's Avatar
Linoge
Jonathan
1985 D90
Chris - looks like the PM got lost in transit. I'll PM you.
John - I'll check with the folks working on it.
Old February 26th, 2014, 10:42 AM
Brewie212's Avatar
Brewie212
Brian Kandefer
believe it's a weber
Old February 26th, 2014, 12:34 PM
Allthingsfast's Avatar
Allthingsfast
Jacques
1988 D90
Parts.
Pm me , il take the dizzy and carb if they are available.
8433235197
Old February 26th, 2014, 01:29 PM
A couple words of advice to potential buyers. I'm pretty sure that in order to get the PS bracket to work you will need the whole timing cover. Unless you can confirm that your engine has the proper timing cover already on it.
Should get the whole PS assembly including hoses and reservoir.
As for the carb, better get the intake and exhaust mainfodls as they are different too. The std. carb is the 32/34 dtml which works a bit better than the weber 32/36 dg series which are sometimes sold as retrofits. IOW, worth the effort to change over. May want the downpipe too as that is also different. Or at least the first few feet of it to use as an adapter.
The cam is a different grind than the series trucks too.
Also worth having would be the oil filter adapter if it is the spin-on type.
Old February 26th, 2014, 07:20 PM
Linoge's Avatar
Linoge
Jonathan
1985 D90
Much appreciated, Ren... The truth is, I'll be yanking out specifically whatever parts people ask for, so do be specific .
Old March 20th, 2014, 01:58 PM
Linoge's Avatar
Linoge
Jonathan
1985 D90
So the whole engine has been yanked out of the bay and is sitting on the shop floor at the moment. Everything aft of the flywheel has been sold off, but everything forward is still up for grabs. Apparently my designs for an end table made from the block may need to be CANEXed - I neglected to account for the small detail of "cast iron". Apparently that thing weighs more than my safe. Anyone know of a range near Raleigh where high-velocity perforation of such things is permitted?
Anywise, stuff off it that is for sale:
Alternator
Distributor (supposedly new)
Spark plug wires (supposedly new)
Starter
Flywheel (recently resurfaced and, I think, with ring gear)
Head (and whatever else is in the head)
Carburetor
Whatever else there is attached to a 2.25L petrol apart from the power steering & power brakes.
I am not going to go digging for all of the prices on those, so contact me with what you figure is a fair offer and we will see what we can do. Go ahead and assume all parts have ~150,000 miles on them, except for the distributor and spark plug wires which were supposedly replaced before I purchased it, but I personally have no idea. I have the documentation on resurfacing the flywheel, though.
Old March 20th, 2014, 03:07 PM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
Jonathan, sorry if I overlooked it, but what direction did you end up going with the replacement engine?
Old March 20th, 2014, 03:16 PM
jimmybuffett's Avatar
jimmybuffett
Tom
Hell On Wheels....
Prices for alt / distrib/ plugs wires/ starter --
Old March 21st, 2014, 10:49 AM
Linoge's Avatar
Linoge
Jonathan
1985 D90
Russell - I ended up going with the complete drivetrain (engine, automatic transmission, and transfer case) from (I believe) a 1995 Discovery; so a 3.9L V8. Certainly not what everyone would have chosen, but it fit our budget and our logistic requirements. While they're in there, I'm having the shop install a second gas tank, and then I'll start fiddling once it gets home to me (hopefully by the 18th of next month).
Tom - Digging into prices on those now .
fs
FS (maybe): 2004 Disco SE 76k- Perfect sans blown block :( monktonrover For Sale - Vehicles 19 February 25th, 2014 07:38 PM
98 GEMS 4.6 Short block FS eliaschristeas For Sale - Parts 1 April 4th, 2011 11:22 PM
FS: used 1995 3.9 V9 long block ECR For Sale - Parts 5 May 19th, 2010 10:12 AM
FS Used 3.9 long block 63K miles ECR For Sale - Parts 1 October 21st, 2008 08:07 AM
