FS: 300TDI 100 AMP Alternator - Page 2 - Defender Source
Old January 19th, 2015, 10:11 AM
BlackField's Avatar
BlackField
Oscar
D110
Originally Posted by rdavisinva View Post
I build a special alternator conversion for the 200TDI Disco engine without AC if you are interested.
My 200TDi has AC and the Allard turbo set up. So my AC compressor on the right and turbo mounted high on the left with the alternator below. I'm running stock V belts.
Will your conversion fit that?
Old January 19th, 2015, 11:12 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Qscar:
If what's in these pictures will bolt to your engine, then the answer is yes.
ID:	111488   Click image for larger version
RDavisinVA
Old January 19th, 2015, 12:10 PM
BlackField's Avatar
BlackField
Oscar
D110
Looks like it will work. I have cleared out the right side of the engine since this pic was taken.
I'll shoot you a PM.
Old January 19th, 2015, 12:36 PM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
Originally Posted by Z.G View Post
Robert, will these fit a Disco style 300 as well? I know the Def/Disco 300s have different alternators, but I'm unsure the actual difference.
These are the standard alt for the disco 300tdi. We sell the same and I installed one into a Disco on Friday.
Old January 31st, 2015, 01:46 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
1 in stock.
RDavisinVA
Old January 31st, 2015, 09:54 PM
Jackie Treehorn's Avatar
Jackie Treehorn
A
1985 (legitimately)
1 in stock.
Robert , I'll take it.
PM and Paypall sent.
Old February 5th, 2015, 02:17 PM
Jackie Treehorn
A
1985 (legitimately)
Got mine today, thanks Robert.
Old February 5th, 2015, 05:58 PM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
Remember 300tdi alternators have two different pulley diameters, 49mm and 63mm. The serp belts are different sizes for these pulleys. I don't think they really effect the belt too much beside some chirping.
Also your tac will be 500rpm off - ask me I know haha.
49mm if you run a 1.4tc and 63mm if you have a 1.2tc normally
1955 Series I
1975 FC101 Vampire
1994 Defender 90 #916
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old February 5th, 2015, 06:04 PM
Jackie Treehorn
A
1985 (legitimately)
thanks for reminding me. Yes, I still have an extra belt from when I ordered two sizes from RN b/c I wasn't sure which one fit.
I still can't remember, but glad you reminded me.
Old February 5th, 2015, 06:21 PM
ini88's Avatar
ini88
Daniel Marcello
would you happen to have a spare 63mm pulley? I need one!
1955 Series I
1975 FC101 Vampire
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old February 5th, 2015, 06:42 PM
Jackie Treehorn
A
1985 (legitimately)
I'll let you know when I get this all sorted out (which may not be for at least a week).
Old February 5th, 2015, 09:09 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
1 more available...
RDavisinVA
Old February 6th, 2015, 07:05 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
I can get new pulleys the same size as the one on the alternator you just received if that will help.
RDavisinVA
Old February 6th, 2015, 06:48 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
1 more available..
RDavisinVA
Old February 8th, 2015, 06:50 PM
Jackie Treehorn
A
1985 (legitimately)
Works well, Thanks Robert.
I did have to drill out the lower mounting tab (it was tapped to receive a 8mm) but the alternator bracket on my 300 had the tapped hole.
Is this because it's a later 300TDI or what?
It was no big deal, but something to consider or verify before you try to replace while on the trail or something.
Old February 8th, 2015, 07:58 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Glad it worked out well.
When I did a trial fit, the bottom bolt matched my 300TDI, but it was a Disco engine.
RDavisinVA
Old February 8th, 2015, 08:08 PM
Jackie Treehorn
A
1985 (legitimately)
For all I know, somebody waaay before me could have helicoil-ed or tapped the mounting bracket to fit some other alternator. All I know is that my mounting bracket fitted to the block is tapped to receive a bolt.
I wonder what iteration of the 300 (if any) is configured like this.
The alternator is a direct fit though and was a breeze to install other than that one thing. Thanks for the fast shipping because today was litterally the only day it has been above freezing in many weeks and it's forecast to be crazy cold starting tomorrow. This needed to get done.
Old February 8th, 2015, 08:28 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Yes those are nice alternators, come with the pulley, and about $80 or more below the going rate...
RDavisinVA
Old March 22nd, 2015, 12:26 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
3 Available.
RDavisinVA
Old March 25th, 2015, 08:21 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Last one up for grabs.
RDavisinVA
300tdi, alternator, fs, tdi
300tdi 100 Amp Alternators navydevildoc Defender Technical Discussions 69 July 27th, 2017 01:29 PM
100 amp alternator fuse location sro Defender Technical Discussions 5 October 27th, 2012 07:59 PM
Rebuilt 100 amp alternator $100 shipped RoverDude For Sale - Parts 0 June 25th, 2011 07:01 PM
100 Amp TDI Alternator - New Red90 For Sale - Parts 1 September 24th, 2010 09:09 AM
100 Amp 300TDI Alternator New Red90 For Sale - Parts 13 May 23rd, 2009 01:07 AM
» Defender Registry
blondy
01CRF10
Fezzik
Factoid
Add your Defender
