FS: 2.5td 19J engine and LT77 gearbox - Defender Source
Old October 24th, 2015, 10:38 AM
shanesherpa
Shane
1987 Defender 110
This is out of my 1987 LHD Defender 110. It is my daily driver, and I'm selling it to convert to a 300tdi and R380 gearbox. Odometer reads 160k kilometers, so about 99k miles.
Engine runs and drives great. Starts right up every time and has fantastic power. Will cruise at 70mph no problem, but I rarely take it over 60mph. Transmission shifts perfectly.
The engine leaks and burns a little oil, about 1/2 quart every 400 miles, which I'm told is about average for this motor. I think it's mostly leaking from around the fill cap, and dripping down the engine. It only drips a few drops each time I stop, so more of an annoyance than anything.
Engine also produces a bit more blue/white smoke than normal. I had my mechanic do compression test on it, and was told compression was good in all cylinders, but he did not recall the actual numbers. This is mostly on start up, but randomly at idle and take off it will smoke more than what I'd think is normal. At other times, it seems to be just fine. I've had several mechanics look at the engine, and have not had a definitive answer as to the problem. Rather than throw parts at it, I've decided this is as good enough a reason as any to do the conversion, so you could be getting a very strong low mileage motor with nothing more than a timing issue for a steal, or you could be looking at a ring job.
I have not pulled the motor yet so if you're in the NYC area your welcome to inspect and/or drive it. I will be taking the vehicle to Virginia for the conversion, so if you're located between these two places, I could potentially bring the motor and gear box to you on the way back up, save you some money on shipping.
I'm asking $2500 for the lot
ID:	133062   Click image for larger version
Old October 26th, 2015, 01:38 PM
shanesherpa
Shane
1987 Defender 110
Or make offer, would like to try to sell this before I pull it.
Old November 3rd, 2015, 02:38 PM
bossman429's Avatar
bossman429
Adrian
1988 90
Could you be farther away??
Might be interested in the tranny but i think the shipping would kill it
Old November 3rd, 2015, 02:52 PM
slorocco
Dan Prasada-Rao
1963, 109 Station Wagon
Did you read the whole ad???? I think the truck is on the east coast not far from you man.
Old November 3rd, 2015, 02:58 PM
shanesherpa
Shane
1987 Defender 110
Hah! Yeah, shipping from Alaska would be brutal, but the rig is in New York. Unfortunately I've decided to do a valve job instead of the conversion, I didn't get much interest in selling an old 19j motor, go figure. If I hear of someone with a lt77 for sale I'll let you know.
Regards,
Shane
Old November 3rd, 2015, 06:05 PM
Regards,
Shane
Adrian, PM me if you are looking for an LT77. I may be able to help.
Old November 3rd, 2015, 06:36 PM
bossman429's Avatar
bossman429
Adrian
1988 90
Appreciate the offer. Not in a desperate need but i will need an entire drivetrain (engine/trans/TC) at some point in the not overly distance future.
Old November 3rd, 2015, 07:03 PM
Scottyoh's Avatar
Scottyoh
Enigma RnR
'87 127"
I'll have this same combo for sale in a few weeks.
Pres - Florida Land Rover Club
Rovers 'n' Racing
407-720-9450
engine, fs
2.5td (19j) oil filler cap to valve cover icnsltmfg Defender Technical Discussions 0 April 18th, 2015 02:05 PM
2.5TD 19J Turbo Boost Pressure Numbers? richord Defender Technical Discussions 1 August 25th, 2014 02:19 PM
Oil Leaks and Pressure build up on 19J 2.5TD Engine richord Defender Technical Discussions 9 August 13th, 2014 06:16 PM
2.5TD (19j) onto Series III transmission SkinlessFrank Series Technical Discussions 5 July 9th, 2013 02:28 PM
Thoughts on a 2.5TD 19J tomaco1 Misc. Chit-Chat 1 December 5th, 2010 08:47 PM
