Front Radius arms reinforced and cantered. - Defender Source
Old September 20th, 2014, 04:01 PM
ron's Avatar
ron
Ron
1994 NAS Defender 90
Smile Front Radius arms reinforced and cantered.
Front Radius arms reinforced and cantered. not sure who made them but they are heavy duty....
$300 plus shipping
Name:	parts 0914 031.jpg
ID:	103302   Click image for larger version
Name:	parts 0914 032.jpg
good luck with your search
Old September 20th, 2014, 08:34 PM
cellulararrest's Avatar
cellulararrest
Chris Snyder
1994 D90 #614 | '07 L322 SC
Any good way to find out how many degrees of correction?
Old September 20th, 2014, 09:10 PM
sloanfiske's Avatar
sloanfiske
Anthony Nelson
If they're off what I'm thinking, it should work on your rig with what you've gone and done. Btw, did you get the rims from Scott?
Old September 20th, 2014, 10:16 PM
Brewie212's Avatar
Brewie212
Brian Kandefer
Look like RTE?
Old September 21st, 2014, 08:04 AM
Buddy Lee
Tobias
TBD
They are RTE or someone copied their design. RTE does not do degree adjustments they do it based on inches of lift. Best way to see how much is to lay a stock RA on top of it line up the holes and measure the distance between the studs.
Old September 21st, 2014, 08:28 AM
cellulararrest
Chris Snyder
... Which determines the amount of correction measured in degrees.
Yeah I think they'd be okay. I'm going up to SG 3" springs so I think I'm going to want to correct my castor. I'm kinda sensitive to it..
Old September 21st, 2014, 09:38 AM
ron's Avatar
ron
Ron
Smile
I think dan beat you to them if he doesn't materialize with cash your next... the truck had a 3 inch lift.....
not sure who made them but they are stout...
I may have a 3 link if you are interested in that...
Offset Radius Arms and Rear Trailing Arms OBXrover Wanted 0 September 28th, 2013 01:36 PM
How do Caster Corrected Front Radius Arms Help? IPSC_GUY Defender Technical Discussions 14 May 5th, 2010 11:06 PM
Bolt size for Radius Arms and Rear trailing arms Rugbier Defender Technical Discussions 5 May 29th, 2009 10:23 AM
Radius arms or trailing arms sflash868 Defender Technical Discussions 12 May 28th, 2006 05:40 PM
Reinforced Tow Hitch TurkD90 Defender Technical Discussions 14 March 19th, 2005 12:22 PM
