Free 109 SW Fuel Tank in NOVA - Defender Source
Old November 5th, 2012, 09:00 PM
Bricktop's Avatar
Bricktop
Jon Paulikonis
1998 Discovery
All:
Is one man's trash another's treasure?
I have the original 109 SW fuel tank sitting in the back of the Stage 1. It was not leaking, but caused painful rust in fuel issues for me.
It might be able to be reconditioned, but I did not have time to screw with it, so I bought a new tank.
BTW, it is full of diesel fuel...so if you have one of those heaters that burn any fuel, you might be able to use it.
Free for pick-up only in NOVA. I'll check this thread but it is best to email me at jpandlp@cox.net.
Old November 5th, 2012, 09:03 PM
If this is the same as a row d90 tank i will take it.
Abrooks's Avatar
Abrooks
Tony Brooks
Hmmmm . . . I do need a tank of gas, but I'm not sure I need a tank full of gas . . .
Old November 5th, 2012, 09:05 PM
Bricktop's Avatar
Bricktop
Jon Paulikonis
1998 Discovery
I do not know if this is the same as ROW D90, but it's yours if you want it!
------ Follow up post added November 5th, 2012 09:08 PM ------
Hey Tony! I hope the 110's doing well...yes, it hurts throwing away a tank of diesel, but it doesn't hurt as much as a non-running Rover! You should have seen the "little electric fuel pump that couldn't" after clogging up with rust...
Old November 5th, 2012, 09:27 PM
Abrooks's Avatar
Abrooks
Tony Brooks
Is she running better now?
Old November 5th, 2012, 09:45 PM
Bricktop's Avatar
Bricktop
Jon Paulikonis
1998 Discovery
So far, so good. I've been driving it a lot lately. Found a lot of warts on that rear chassis when the tank was out. I'll try and preserve the chassis as much as possible, and in a few years, she'll need a chassis.
By then, probably the only thing that's going to look Stage 1 will be the bonnet and grill. I envision a 200 or 300 Tdi with R380, but I'll keep the leafs!
Old November 5th, 2012, 10:47 PM
Bill Adams needs this tank
Old November 6th, 2012, 12:40 AM
87 D110 (Ruby)
Bill needs a lot more than this tank .... hehehe
Old November 6th, 2012, 06:12 AM
Yes, PLEEEZ!!!
Old November 6th, 2012, 06:38 AM
Go for it bill. I don't tgink it will fit a defender
Old November 6th, 2012, 08:17 AM
It won't. See here for a possible solution for you though
http://siteground237.com/~gunsandr/s...num-Fuel-Tanks
Originally Posted by pendy
I'm here for the D's
Old November 6th, 2012, 08:38 AM
I have 5 fairly good sized aluminum marine tanks sitting around. I could cut those up and make a very nice tank. Anyone know how to weld aluminum? Tho, I guess I could flange the seams and glue them with 5200....hmmm...
Old November 6th, 2012, 09:10 AM
Firemanshort's Avatar
Firemanshort
David Short
1980 Stage One 109
If this is a true Stage One fuel tank - then it is different than the 4cyl petrol fuel tank becasue it has one extra return pipe fitted to the top of the tank. The Stage One fuel tank (V8) is teh same as teh 4cyl diesel but not the petrol - all to do with that return pipe.
As stated - it is not a bolt in fit to a Defender application.
Mine rusted out and started leaking a few years ago and required a replacement.
Firemanshort
1980 Stage One 109
Sterling, VA
Old November 6th, 2012, 11:13 AM
http://siteground237.com/~gunsandr/showthread.php?2576-Aluminum-Fuel-Tanks
Thanks Charles, but apparently it doesn't fit.
I'm still keeping my eyes open for a cheap ROW tank to pop up somewhere.
Old November 6th, 2012, 03:01 PM
If it's a decent thickness I can TIG it up for you. Kang has a tig as well as mattm
Old November 6th, 2012, 04:28 PM
Maybe I'll do that! The tanks are all 1/8 thick I think.
Old November 6th, 2012, 06:46 PM
Bricktop's Avatar
Bricktop
Jon Paulikonis
1998 Discovery
Sorry for the delay responding.
Well, a new standard 109 SW tank worked in the Stage 1, and David is correct, it needed an extra tap. That said, it should work for you, Bill, as you can either plug the extra line tap or run another vent.
Let me know. I did get your message, and I will respond via email, as well. I need to get plugged into the happy hours, but in case I can't make it, if there's anyone who would like to drop by and transport it for you, that's fine, too.
Old November 26th, 2012, 09:42 PM
Jon if this is still available I would like to grab it from you.
Old November 26th, 2012, 10:04 PM
Waiting to hear from JP re: pickup/drop off.
Old November 27th, 2012, 07:55 AM
Also my 109 seems to have a newer tank if you want it Bill
109, fuel, fuel tank, nova
Factory Aux. Fuel Tank? Willh Misc. Chit-Chat 20 May 10th, 2010 09:39 PM
Opinions on Fuel Tank Vendors ajh Defender Technical Discussions 11 January 28th, 2009 12:26 PM
Fuel tank skid plate GeoParth Defender Technical Discussions 53 June 25th, 2006 03:21 PM
Rimmer Supercharger, complete. Also side fuel tank. Tom Fitzgerald For Sale - Parts 14 December 12th, 2005 08:09 PM
Dropping the gas tank Gkase Defender Technical Discussions 33 December 1st, 2003 08:59 AM
