Feeler - Console base/spacer - Defender Source
Old August 1st, 2012, 12:52 PM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
I made myself a spacer/base to mount beneath my Tuffy in the 90 out of some 1/4" aluminum angle (3" legs) and 1/8" flat stock. Basically the unit was designed to both raise my console approximately 3" which I think makes it more comfortable and it also allowed me to gain additional storage space beneath the console that is "secure". I installed my stereo amplifier, the control box for my Cobra 75 CB and some relays for various electronics within the base.
Anyways, I am now making one for another forum member so I figured I would put the feeler out to see if other folks are interested as well. I still have enough material for several more units because of the lengths I had to get.
My current design/dimensions are for the 12" wide Tuffy box but I can customize if needed. Also, I made the base so that it extends forward of the Tuffy about 2-1/2" to close up the gap between the console and the MUD tunnel tray. This also gave me a nice place to mount a 12V outlet and the remote lead for the CB. Additionally, I notched it to fit over the bump in the seat base so it essentially locks the console base in place. I also installed a stainless steel piano hinge to allow me to pivot the console up to access the electronics beneath.
I am thinking pricing would fall somewhere in the $75-100 range depending on interest and any customizing that may be requested. Please let me know if you are interested.
ID:	54978   Click image for larger version
ID:	54980   Click image for larger version
Old August 1st, 2012, 01:01 PM
Cool idea. Where is the piano hinge?
Old August 1st, 2012, 01:06 PM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
Sorry, realized I didn't actually have a pic of the piano hinge so will have to take one later and post. Basically the hinge mounts to the rear of the base and then into the bottom of the console. I can get my console (which has a cup holder mounted on the back) to about 60* before it hits the bar and can go to almost a full 90* without the cup holder.
Old August 1st, 2012, 01:16 PM
That would be nice. I'm having trouble picturing how it as a whole. Can you take a pic (installed) from behind the front seats as well? The way I'm picturing it in my head there'd be a little interfere with the W bar portion of the rollcage behind the front seats. Also, does your box now utilize the captive nuts under the truck that the Tuffy used before, and the Tuffy just bolts into the top your box without going all the way through to the captive nuts below the truck?
Old August 1st, 2012, 01:22 PM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
I will snap a photo for you later this afternoon...but yes, the base mounts to the captive nuts at the front of seat base and at the rear. I also added two more mounting points in the middle because I think a PO had added mounting holes there too but I don't believe the additional mounting points really do anything. I then just marked, drilled and tapped holes in the top for the Tuffy to mount to. Part of the reason for the 1/4" aluminum was to have something beefy enough to get a few threads on for mounting the Tuffy
Old August 1st, 2012, 01:56 PM
Sergeant_V's Avatar
Sergeant_V
Abel Villesca
1995 D-90 ST
I'd be interested. I have a Tuffy I haven't installed yet. I'm not sure it is the same size, though.
Old August 1st, 2012, 02:19 PM
Do you have a Tig or a spool gun? I've got a friend that needs some minor repair on the rear corner of his tub.
Jeff, I TIG aluminum. Feel free to pm me with what he needs done.
Old August 1st, 2012, 07:47 PM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
Josh, hopefully these photos help...
#1 - Rear of console as is (installed with cupholder)
#2 - An attempt at a hinge photo
#3 - Inside hinge photo
#4 - Rear of console open with cupholder
#5 - Angle console opens to with cupholder
#6 - Rear of console without cupholder
#7 - Angle console will open to without cupholder
Briggs, I have actually been brazing these together so far but plan to switch to a spool gun if I continue making them.
ID:	55047   Click image for larger version
Name:	Inside hinge.jpg
ID:	55049   Click image for larger version
Name:	Rear open with cupholder.jpg
Name:	Open with cupholder.jpg
ID:	55051   Click image for larger version
Name:	Rear open without cupholder.jpg
Name:	Open without cupholder.jpg
Old August 1st, 2012, 09:14 PM
Sweet Ed, do me a favor and get cracking on this. I'm hoping I can buff it out, but if not what do you think - may take you an hour or so to TIG?
Should I use the red or the white rubbing compound first?
Can you say "wrenching party"?
Old August 1st, 2012, 09:18 PM
jayz's Avatar
jayz
Jason Zolezzi
85 200tdi 110
Is it vented? Does the amp generate much heat? I was thinking of doing something like this but putting one of those little computer fans on a thermostat to move some air through it
Old August 1st, 2012, 09:26 PM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
You may be able to see in one of the early photos that I have a 1" diameter hole in one corner...this is right next to the amp and I figure I can add a fan as well if needed. That being said, I have had the stereo on all day wheeling in 100*+ and no issues so far. I did however put some dynamat beneath the whole setup to try to keep the heat from the trans/t-case to a minimum.
Old August 1st, 2012, 09:39 PM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
Wow. Jason, I hope you and family (including the wolfers) are okay. That looks like a solid hit.
Old August 1st, 2012, 10:45 PM
Finally a chance to use my Harbor Freight dolly and hammer kit!
That's crazy Lav...how did that happen?
Old August 1st, 2012, 10:50 PM
Long story staring with a faulty parking brake and ending with a stone wall. Will catch you up to speed over many, many beers at Rausch.
Old August 2nd, 2012, 04:12 PM
BCN's Avatar
BCN
BRIAN
94/D90/#1337/AA YELLOW
Like very much. Sending EM.
Old August 5th, 2012, 10:31 AM
Rugbier's Avatar
Rugbier
Gustavo
Huffy,
I take one of those bases, I think it is a cool place for a firearm.
Can we add a lock?
I take one regardless
NO SIGNATURE
Old August 5th, 2012, 10:52 AM
Jeff, good pics - exactly what I was wondering about. Does it rattle over bumps or on the trail or anything? Gustavo has a good point with the lock-it-down suggestion. When do you need to know by?
Jason, I figured one of your German Shepherds ran into the back of that thing! Glad you're all alright.
Goose - new truck?
Old August 5th, 2012, 11:01 AM
Rugbier's Avatar
Rugbier
Gustavo
Goose - new truck?
No, I will put it in the 911... it will look nice
NO SIGNATURE
Old August 5th, 2012, 02:56 PM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
Glad to see you back buddy! you have been gone too long...you coming to HH? we can talk about what you are thinking for a lock
Old August 5th, 2012, 03:06 PM
Huffy,
Can we add a lock?
x2 put me in for one, preferably with a lock a la Goose.
ac, console
FS - LR OEM Center Console w/radio - 1995 jam90 For Sale - Parts 2 January 19th, 2006 11:31 PM
Looking for 97 NAS90 centre automatic console DEF110 Wanted 2 November 22nd, 2005 02:24 AM
SW driver/passengerside doors wanted as well as centor console tub jchan88 Wanted 4 August 7th, 2005 09:04 PM
Custom Console for a '97? Chaucer Misc. Chit-Chat 3 May 24th, 2004 06:41 PM
Cheapest place to buy a tuffy center console JRowe Defender Technical Discussions 3 October 6th, 2003 10:42 PM
