Feeler: 2.5 NA with lt77/tcase also frame, axles - Defender Source
Old December 5th, 2012, 06:48 PM
NPT90's Avatar
NPT90
JT
D90 óriginalé
Potentially a home run for someone with a Series they are looking to get on a coil sprung chassis...
Bought a whole mess of parts for my 85 but I will be left with the following after my build:
Frame (repairable, potentially, needs rear extension but I will confirm condition when I inspect)
Axles 10 spline:
RHD front[might be LHD when I am done with them]
rear[drum] (good condition, could use a scrape and paint, maybe bearings in the front)
associated steering components potentially radius and trailing arms as well (need to confirm)
Engine:
2.5 NA diesel with glow plugs (hold for 10 seconds) original with 115K, IMMACULATE, strong runner, some smoke when it is cold, all engine auxiliaries and radiator (most likely PS reservoir as well)
transmission:
lt77 locked up on me six months ago, I would assume a rebuild is needed
and tcase would be included
Would consider breaking up if no one has a series project that could use the whole 9
would happily take $1600 for everything if there is interest otherwise I will start posting separately as pieces come off.
PM me if you are interested in anything above.
JT
Old December 5th, 2012, 07:19 PM
RX6RCROL's Avatar
RX6RCROL
Matthew Hedrick
1994 D-90 #646
Pm sent.
axle
2.5 na diesel in a 110- Advice? TCarawagon Defender Technical Discussions 6 March 20th, 2012 08:11 PM
Feeler: WTB a D90 galvy frame and misc other parts. Roving Beetle Wanted 5 April 4th, 2011 09:02 AM
D90 ExMOD 2.5 NA SW Stalling out trybul Defender Technical Discussions 17 February 15th, 2011 03:05 PM
Where to buy 2.5 NA diesel weld in motor mounts? dave_lucas Defender Technical Discussions 15 July 26th, 2009 10:18 PM
108" sprung frame, T-cases, axles Method PHX For Sale - Parts 0 November 17th, 2005 06:26 PM
