Extra Heavy Duty Steering Tie Rod DI/Defender RRC - Defender Source
Old September 2nd, 2013, 07:25 PM
RoverDude
John Gadd
Many
Complete new Max Yedor Tie Rod (behind front axe) for $200 shipped (to the East Coast) or less.
This is a .250 wall DOM tie-rod, running a 3/4"" heim at each end. This is much, much stronger than a Rover TRE and decently stronger than at Chevy 1-ton TRE. Plus, they're cheaper and easier to track down a replacement if the time comes. The downside is that you'll need to drill out the steering knuckles with a 5/8" bit for the bolt to drop through, but all you need is an $10 bit.
These are out of production. Sp, if you have one you are lucky. If not, here's your chance.
Contact me if interested.
roverdudeATsbcglobalDOTnet
7I4-7I9-7I23
Old September 2nd, 2013, 09:12 PM
SkinlessFrank
Sean
1984 Defender 90 (2.5 TD)
What is the length of the tube...without the TRE?
Sean
Old September 3rd, 2013, 12:01 PM
RoverDude
John Gadd
Many
Thanks, Sean
45 3/8" for rod only.
This was my unused spare. Don't believe I will ever use it, so up for grabs.
Heavy Duty Steering Kit RoverDude For Sale - Parts 2 September 12th, 2012 03:34 PM
Heavy Duty Track Rod Kit with Tie rod ends $250.00 SafariHP The Vendors Loft 0 August 30th, 2012 04:20 PM
Heavy Duty Steering Links Oliver Whiting The Vendors Loft 0 August 15th, 2012 10:06 PM
Heavy Duty Steering Kit: DI, RRC & Defender RoverDude For Sale - Parts 2 April 2nd, 2012 08:27 PM
GBR heavy duty drive flanges jorge Defender Technical Discussions 2 February 29th, 2004 11:51 PM
