EXT009-12 Acoustic Moulded Matting System - Defender Source
Old June 24th, 2011, 04:13 PM
Fivespddisco's Avatar
Fivespddisco
Justin Monnin
96 D1
Ordered this for a customer who ran into financial difficulties.
This is truly the best stuff we've put into a truck. The quality is unbelievable!
Retail price is $869.42
Selling for $650
LT77 Acoustic Molded Matting System
This is the only front matting system available that is approved by Land Rover and the Ministry of Defense. This is the Kit. Already fitted to most military Land Rovers and used in extreme environments, this kit has proved itself to be up to the job time and time again.
Supplied as a 3 piece kit with the floor & tunnel in one piece with the seat box totally covered and the bulk head center. The seat box section will require cutting to allow access to the storage sections and gear box access plate. You will also need to clear the holes to suit your vehicles required seat mounting points or any other equipment you may have installed.
Approved at Millbrook testing ground and reduces the noise and heat levels in the front to below required safety standards.
Easy to clean
Heat deflective
Water repellent• Extremely hard wearing
Acoustic rubber underside for noise suppression
Drastically reduces noise
For expedition tested Rover gear Check out
716-898-8153
Old June 24th, 2011, 09:16 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
Looking for the R380 if you happen to have a deal on them.
Land Rover 110
Old June 24th, 2011, 09:44 PM
Fivespddisco
Justin Monnin
96 D1
You have no idea how much this is killing me. I wish it was an r380 because it would be in my truck.
716-898-8153
Old June 24th, 2011, 11:47 PM
DreamRover's Avatar
DreamRover
AJ
ROW 1984 D90
Do you know a way to figure out which gearbox you have. I have a 1984 ROW defender, and I have always heard that older vehicles have the LT77, but is there something I can look for. In other words I believe im interested in buying, if it fits? Any suggestions of figuring out which gearbox?
Old June 25th, 2011, 12:12 AM
cdb
Clark Bowen
R380 has reverse to the far right and back
2011 RR HSE -
2001 GMC 2500 4wd
Old June 25th, 2011, 08:22 AM
Rugbier's Avatar
Rugbier
Gustavo
LT77 has reverse next to 1st gear
NO SIGNATURE
Old June 25th, 2011, 10:03 AM
meatblanket's Avatar
meatblanket
Mike Simpson
1955 86 1986 ExMOD 110
PM sent.
Old June 26th, 2011, 07:26 PM
DreamRover's Avatar
DreamRover
AJ
ROW 1984 D90
Ok then it fits my truck
Old June 26th, 2011, 08:27 PM
Weldon's Avatar
Weldon
Weldon Pundt
"95" D-90
http://allmakes4x4.com/exmoortrim/pr...?cat=52&grp=91
Weldon
Old June 26th, 2011, 10:54 PM
James Pierce's Avatar
James Pierce
James Pierce Jr.
Justin,
I have an R380 mat set that is 6 mos old I am pulling out of my truck if you want a good deal on a set. 495+sipping.
James
Old June 27th, 2011, 06:36 PM
Fivespddisco
Justin Monnin
96 D1
sold
716-898-8153
ac
Acoustic Molded Mat System R380 SafariHP The Vendors Loft 37 August 7th, 2009 01:21 AM
Anyone have experience with Wright Off-road - Acoustic Mat System themaxx Misc. Chit-Chat 9 January 19th, 2007 10:24 AM
Double "S" Stainless Steel Exhaust System edducati Defender Technical Discussions 11 July 23rd, 2004 10:43 AM
rail system hooks & anchor point mounts paulb Defender Technical Discussions 2 November 24th, 2003 01:16 PM
