Everything you need to rebuild & stroke your 3.9 / 4.0 - Defender Source
Old January 22nd, 2015, 09:21 AM
James Pierce's Avatar
James Pierce
James Pierce Jr.
I basically have everything you need to stroke and rebuild a 3.9 or 4.0 to make it a 4.6. All parts with exception of crank and rods were purchased from Turner Engineering and are in new condition.
4.6 Crank (machine shop said it would polish and make standard)
4.6 Rods (not pictured)
4.6 Pistons (standard size)
Rod Bearning Set
Main Bearing Set
Cam Bearing Set
Crank Shaft Bushing (for using a 3.9 front cover)
Valve Springs
Rocker Shafts
ARP Head Studs
Seals for Cross Bolts
Freeze Plugs
Crank Shaft Bushing (Standard Transmission)
Kent Cams 180 Sprot Torque Camshaft
Lifters
Top End Gasket Set
Bottom End Gasket Set
$2000 shipped CONUS
Old January 22nd, 2015, 11:18 AM
BigWalker's Avatar
BigWalker
Pete Ricci
1965 Series 109 V8 Automatic
PM sent with questions
Old January 22nd, 2015, 12:28 PM
James Pierce
James Pierce Jr.
I guess I should add that is kit was intended for use with a 3.9 front engine cover. The camshaft has the drive gear for the distributor. If you are wanting to build a Gems or Bosch engine you would need a different cam. I would be willing to sell the cam separate if that were the case. Not interested in parting anything else out though...
Old January 22nd, 2015, 12:41 PM
BigWalker's Avatar
BigWalker
Pete Ricci
Don't split it up yet, I'm still counting my pennies, since I have a 3.9
Old March 1st, 2015, 12:09 PM
James Pierce
James Pierce Jr.
For some reason I cannot edit my original post... New price $1900 shipped conus
Old March 1st, 2015, 12:18 PM
drdread's Avatar
drdread
AL
'94 NAS 90 SW
PM sent
1994 Silver DEFENDER 90 NAS SW
Old March 1st, 2015, 12:44 PM
D90Overkill's Avatar
D90Overkill
David Frank
1995 ST #2615
Pm'd
Old March 1st, 2015, 12:50 PM
That crank won't work in a 3.9 block without significant machine work.
Old March 1st, 2015, 10:07 PM
mud ruts's Avatar
mud ruts
Chris Ray
97 Disco
I think he planned to use a 4.0/4.6 block with a 3.9 front cover.
Mud Ruts Off-Road Rover Repair shop 614.301.1574
Old May 22nd, 2015, 11:05 PM
James Pierce
James Pierce Jr.
^^^ That is correct. I had originally planed to use a 4.6 block that wound up being cracked. The parts will work without modification in a 4.0 or 4.6 block. It is my understanding the mains would need to be ground down to fit in a 3.9 block.
Would like to get these sold and move on to another project.
$1800 shipped Conus OBRO
Old June 9th, 2015, 10:37 PM
jamesepoop
James
'96 Disco
Sent you a PM. Appreciate the reply. Thanks.
Old June 11th, 2015, 08:06 PM
Roverchef's Avatar
Roverchef
Jake K.
95 D90 SW
PM sent
Old June 12th, 2015, 11:43 PM
lynchee's Avatar
lynchee
Dennis Lynch
94 D90 #699
Would this work on an engine out of a 95 Range Rover?
Happen to have one looking to be rebuilt
Old June 13th, 2015, 12:15 AM
LuisC's Avatar
LuisC
Luis Constantin
98 Disvovery 1 LE
The crank needs to be gun barreled and knife edged.
Black Rhino Lives Matter
Old June 18th, 2015, 06:06 PM
lightwriter's Avatar
lightwriter
Carlos Ascencio
'84 One Ten
Is this this available?
Old August 16th, 2015, 10:42 PM
James Pierce
James Pierce Jr.
Sold Thanks D-90
rebuild
Diesel + ATF or 2 Stroke Oil? MUDSUX Defender Technical Discussions 19 July 10th, 2013 03:40 PM
How much $ do you have into your rebuild? One Ten Defender Technical Discussions 23 September 22nd, 2011 03:09 PM
Custom ALuminum Radiator for 2.8 Power Stroke or 300tdi TDI Guy For Sale - Parts 6 July 4th, 2011 09:03 PM
2.8 Power Stroke A/C setup TDI Guy Defender Technical Discussions 12 June 11th, 2010 09:32 PM
Help! My Defender Had A Stroke! AggieD90 Defender Technical Discussions 2 July 1st, 2008 05:11 PM
