ECR oil cooler lines FS (used) - Defender Source
Old January 14th, 2011, 10:48 AM
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
FS used take off oil cooler lines for a 1993 NAS 110 or 1994-1995 NAS 90 with removable fitting radiator. These lines work with the Mocal SP1 plate. They were sold to a customer with a 1994 NAS 90 and we found that on early 94s there is a PS line issue that can cause a tight fit. So we made the customer a different set of lines to work in his truck and he returned these. Problem is that the shop that installed and removed them put a hurting on the fittings cosmetically so they are still 100% functional, but no longer pretty. Therefore we can not sell them retail.
So $100. plus shipping and they are yours.
Email:
Old January 14th, 2011, 11:14 AM
NoVaKevin
Kevin
sold#1469
ill take them
Ill take them. If I don't need any other parts and they are good to go. They will fir a 94, right?
Old January 14th, 2011, 11:18 AM
I was hoping you'd get these. You should probably call Holly before someone else does, though.
I'm assuming these were on FounD90's truck?
Old January 14th, 2011, 11:22 AM
ECR's Avatar
ECR
They will fit a 94 if you have the removable fitting radiator (most 94s do, but you have to check because if your radiator has been replced they may have installed the 97 type (fixed fitting)).
Go to our web site to see what radiator you have:
http://www.eastcoastrover.com/110oillines.html
You will also need a Mocal SP1 and 2x 8AN fittings for the Mocal.
Those you can buy from us, or you can source them from many other places on line if you like.
------ Follow up post added January 14th, 2011 11:23 AM ------
Not sure. Not good with screen names.
Email:
Old January 14th, 2011, 11:24 AM
NoVaKevin
Kevin
sold#1469
Pm me a total plus shipping to 22201. Im gonna confirm the radiator in a few.
Old January 14th, 2011, 11:34 AM
Hazard's Avatar
Hazard
David Hazard
95 D-90
If his radiator doesn't work, I'll take them!
95 D-90 3" lift, 35" Baja claws, salisbury rear axle, 4.88 gears, lockers, winch, etc
Old January 14th, 2011, 11:36 AM
ECR's Avatar
ECR
Call Holly to purchase.
She can estimate shipping. I have no idea.
207-594-8086
Email:
Old January 14th, 2011, 02:45 PM
NoVaKevin
Kevin
sold#1469
They will work. Holly said you all would be gone by 2: have her call me when available to settle up. 7032168856.
Old January 14th, 2011, 04:14 PM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
Kevin, this is probably one of the better places to get the Mocal sandwich plate as you will need this as well (as stated above). If memory serves you need the SP1T. Not sure what ECR sells these for
http://www.racerpartswholesale.com/c...Sandwich_Plate
Old January 18th, 2011, 11:16 AM
ECR's Avatar
ECR
Bump
Still available
Email:
Old January 18th, 2011, 12:33 PM
NoVaKevin
Kevin
sold#1469
Called again. no answer. no answering machine.
Old January 18th, 2011, 12:41 PM
ECR's Avatar
ECR
Wrong number then, or Holly was on the other line (there are 3 lines and only 1 Holly) .
207-594-8086
We are here until 5 pm today.
Email:
Old January 18th, 2011, 02:42 PM
ECR's Avatar
ECR
Sold
Email:
ecr, fs
oil cooler lines CHRIS C Defender Technical Discussions 39 December 21st, 2004 11:30 PM
Oil cooler lines revisited rover4x4 Defender Technical Discussions 5 July 9th, 2004 08:40 AM
Stainless Oil cooler lines??? Neo Defender Technical Discussions 3 February 3rd, 2004 08:04 PM
