Ebersbacher heater - Defender Source
Old January 29th, 2010, 11:32 PM
kellymoe's Avatar
kellymoe
kevin
defender 130
Ebersbacher heater
I just removed my Ebersbacher from my truck today. It has always run, fan blows but I had disconnected the fuel line to the unit after I bought the truck so I dont know for sure if the heating element is working. When I bought the truck the PO said he used it often so it probably does work.
This is a feeler to see if there is any interest. I will remove the rest of the wiring and attempt to get some pictures tomorrow.
Any interest? I am thinking around $200
Old January 29th, 2010, 11:44 PM
dave_lucas's Avatar
dave_lucas
Dave Lucas
What fuel does it run?
Old January 29th, 2010, 11:54 PM
kellymoe's Avatar
kellymoe
kevin
defender 130
Petrol
Old January 30th, 2010, 12:46 AM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
Let's see some pics! I may be interested in this, but I've got to do a little reading first.
Anyone have any words of wisdom about these?
Old January 30th, 2010, 01:54 AM
BEIS's Avatar
BEIS
RYAN BEIS
D110 Soft Top with full rollcage
What do these do?
-Ryan
Old January 30th, 2010, 12:14 PM
andyrad
Andy Radlgruber
None.
They can do a few things but for a D-90 this one probably is being used as an auxiliary heater to keep the cab warm. We all know that a LR heater does not work too well in the extreme cold so this is the bees knees. Diesels are supposedly worse for heat but this is a petrol unit. These are 1200 CDN new so 200 is a steal.
Some people are so heavenly minded that they are NO EARTHLY GOOD!
Old January 30th, 2010, 12:45 PM
kellymoe's Avatar
kellymoe
kevin
defender 130
Have not had time to take any pictures yet, hope to get to it today a bit later.
Old January 30th, 2010, 04:22 PM
kellymoe's Avatar
kellymoe
kevin
defender 130
Here are a few pictures. Dont be alarmed at the picture of the back of the unit, it's what was exposed to the elements and looks ratty, those bits would be replaced with new hardware anyway.
The picture of the back of the unit shows the exhaust, fuel line and condensation port.
The unit was functional when I removed it. It needs a new switch for the dash that I believe is a starter that warms the unit, fan and on/off. Someone who knows more about them can chime in but I am sure you can still get proper pieces for them as they are pretty popular units worldwide.
Asking $200 firm buyer pays shipping.
ID:	24771   Click image for larger version
ID:	24773   Click image for larger version
Old February 1st, 2010, 10:44 AM
kellymoe's Avatar
kellymoe
kevin
defender 130
Anyone?
Old February 1st, 2010, 11:07 AM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
Wish it was the D1L. If I had a gas motor I would snatch this up.
If no one buys it here try a VW site, many of the old campers run the B1L.
Old February 1st, 2010, 11:41 AM
BEIS's Avatar
BEIS
RYAN BEIS
Is this easy to install? I could definitely use a better heater for my truck for the interior
-Ryan
Old February 1st, 2010, 11:46 AM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Would love to dive right on this, but just can't swing it right now unless you want to swap for that Megasquirt ECU I'm selling (which I highly doubt).
-Hans
My oil line fix
My 100k stopped odometer fix
Old February 1st, 2010, 12:12 PM
kellymoe's Avatar
kellymoe
kevin
defender 130
How would that work on a 3.9? I am rebuilding 3.9 to replace my ailing 3.5.
-Hans
Old February 1st, 2010, 12:22 PM
Hans's Avatar
Hans
Hans Haase
Would need some wiring modifications as well as programming of the ECU. Would work, but honestly it's nowhere near a drop-in fit.
-Hans
My oil line fix
Old February 1st, 2010, 03:35 PM
kellymoe's Avatar
kellymoe
kevin
defender 130
I'll have to pass.
-Hans
Old February 2nd, 2010, 04:42 PM
kellymoe's Avatar
kellymoe
kevin
defender 130
Here is a picture of the filter/regulator that was mounted near the gas tank. It worked when I bought the truck.
Old February 2nd, 2010, 06:05 PM
That is the fuel pump. It is not the filter. There should be a filter as well.
Old February 2nd, 2010, 06:22 PM
kellymoe's Avatar
kellymoe
kevin
defender 130
My bad, dont know what happened to the filter unless the PO never had one installed because I cant find it anywhere between where it was mounted and the fuel tank.
------ Follow up post added February 2nd, 2010 11:28 PM ------
Bump before it goes to Ebay.
Old February 3rd, 2010, 01:28 AM
kellymoe's Avatar
kellymoe
kevin
defender 130
sold
Old February 3rd, 2010, 09:09 PM
John_Karlsson
John Karlsson
1966 Series IIA 88 SW
Where was this heater mounted?
John Karlsson
Hope Valley, RI
ac, heater
cables to heater box ? mattdh Defender Technical Discussions 3 March 6th, 2006 09:33 AM
110 Heater Hose Routing newfD90 Defender Technical Discussions 11 February 1st, 2006 02:02 PM
Heater Improvements? And Hi ... again.. EdF Defender Technical Discussions 6 September 13th, 2005 01:51 PM
Rear Window Heater Help mwmcgehee Defender Technical Discussions 0 August 21st, 2004 01:40 PM
heater motor lubricant ??? artm Defender Technical Discussions 1 October 18th, 2003 04:42 PM
