drive shafts and springs - Defender Source
Old August 27th, 2011, 08:20 AM
Oliver Whiting
Oliver Whiting
84 110, 94 NAS90,Bunch of EX-mods
Old Man Emu 755 110 rear springs very low milage $80 for the pair
Old Man Emu 767 front springs also low milage $80 for the pair
Rear drop shock mounts $60 pair
90 rear drive shaft, 90 front drive shaft, 110 front drive shaft, RRC front drive shaft and panhard rod $10 each
plus shipping.
Oliver
ID:	41383   Click image for larger version
ID:	41385   Click image for larger version
Old August 27th, 2011, 08:33 AM
Front and rear springs licked...just need to compare some measurements on this end (and verify shipping to 22312).
Old August 27th, 2011, 08:50 AM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
Seconds on springs if Lav backs out
------ Follow up post added August 27th, 2011 08:54 AM ------
Wait, are you sure the front springs are 767s? I don't see them listed on the OME site
Semper Fi!
Old August 27th, 2011, 09:17 AM
Anyone have any idea of the compressed dimensions of these OME springs? I'm trying to compare it to my current setup on my stock springs (note: fronts are sagging which is why I need to replace, but compressed I'm at FRONT: 9.5"-9.75", REAR: 11.5"-11.75"). Unfortunately I'm limited by my current garage setup at the moment.
I'll do some more homework, but if these work I'll take them definitely.
Old August 27th, 2011, 09:22 AM
James Pierce's Avatar
James Pierce
James Pierce Jr.
By compressed do you mean at ride height or coil bind?
Old August 27th, 2011, 09:35 AM
smob's Avatar
smob
Steve
'97 Arles Blue SW #2131
Rear 90 driveshaft licked - PM coming.
-Ren Ching
Old August 27th, 2011, 11:01 AM
Ride height.
Trying to find spec sheets for OME...anyone have a link?
Old August 27th, 2011, 11:46 AM
Rugbier's Avatar
Rugbier
Gustavo
Jason, you will be find
NO SIGNATURE
Old August 29th, 2011, 12:08 PM
Oliver Whiting
Oliver Whiting
springs and things
plus shipping.
Oliver
90 rear drive shaft sold. Thank you.
springs are still up for grabs along with the drop shock mounts and other bits.
Old August 29th, 2011, 12:25 PM
Wolf Fabrication
Sterling Archer
'08 D3
Still interested in the springs. Can you confirm the front springs are 767s? OME isn't listing them.
Semper Fi!
Old August 29th, 2011, 12:33 PM
grnrvrs's Avatar
grnrvrs
Paul
88
OME767:
http://www.arbusa.com/uploads/PDF/ac...erDefender.pdf
p56, new naming convention 2xxx e.g. 2767
http://www.inlandrovers.com/product_p/ome767.htm
http://www.offroadexperience.com/wcb/emu.htm
They're out there.
Old August 29th, 2011, 01:26 PM
Wolf Fabrication
Sterling Archer
'08 D3
If Jason backs out I'll take the springs. Any idea your overall lift with those springs? 2+" ?
Semper Fi!
Old August 29th, 2011, 01:28 PM
Jonathan- springs are yours...I'm still doing my homework on ride height/lift and may go with an alternate set, but don't want to hold things up for Oliver unecessarily.
Oliver - got your pm's as well, I'll drop you a line soon.
Old August 29th, 2011, 01:35 PM
Wolf Fabrication
Sterling Archer
'08 D3
Email sent....
Semper Fi!
Old August 29th, 2011, 04:14 PM
vlocci
Vin Loccisano
PM sent on the 110 driveshaft.
Vin
Tops, wheels, springs, winch & more!! Rangermeehan For Sale - Parts 16 October 17th, 2010 05:49 PM
drive shaft bjenk Defender Technical Discussions 5 July 1st, 2007 03:04 PM
Expedition Exchange shawnpalmer Misc. Chit-Chat 155 June 4th, 2007 10:56 AM
SG winch bumper, GKN torque limiters, OME 751 springs Shane@EVS For Sale - Parts 24 June 1st, 2006 02:37 PM
Advice on shocks/springs, exhaust jaherring Defender Technical Discussions 29 August 30th, 2004 08:57 PM
