Door hinges and screws. - Page 3 - Defender Source
Old February 10th, 2012, 04:42 PM
pendy's Avatar
pendy
jim pendleton
89'd90
Originally Posted by bjf View Post
It's weird. The hinges seemed fine but some of the bolts the heads corroded and some the threads. I will wire wheel them but I think the coating is the issue if you scratch it they must corrode quickly. The coating seems to bubble.
Yes I am curious. If the bolt still has its original finish I would consider it a stain. The pin itself in the hinge is what bleeds the rust on the fateners and hinge. The part of the pin inside the center section that pivots in particular. A stainless hinge pin is the real solution IMO. And a stainless sleeve in the hinge center section. Grease zerk would be nice as well.
legend in my own mind
Old February 10th, 2012, 04:50 PM
I copied the whole thread to the technical area as it long since passed as a classified thread, here: http://www.defendersource.com/forum/...ad.php?t=35690
Please continue the discussion there.
Old February 18th, 2012, 07:58 AM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
I got a couple PMs asking about bolts and hinges.
If you want bolts that look factory this is your only choice:
http://nakatanenga-tours.de/shop/cat...aram=cid%3D%26
As for hinges the td5 hinges are a huge improvement over the stuff that came on the NAS trucks and easy enough to get. I think Safari Rover sells take off hinges. I am curious about the ECR/Cryotec ones but they might be super expensive.
Barry,
Thanks for the link. Just ordered a set.
door
Steering column cowl screws rover4x4 Defender Technical Discussions 1 December 11th, 2010 12:12 PM
Stainless hinge/hood screws & ARB Skid Plate GMFett Defender Technical Discussions 7 October 21st, 2009 12:28 AM
stripped lens screws? Caribsurf Defender Technical Discussions 4 July 10th, 2007 05:42 PM
Safari Guard grill screws needed Caribsurf Defender Technical Discussions 7 February 26th, 2007 03:57 PM
Rear Door Hinge Screws Rob Defender Technical Discussions 1 October 12th, 2003 06:46 AM
