Disc brake axle, 10 spline 1/2 shafts - Defender Source
Old April 11th, 2014, 01:21 PM
Roverlab
Trevor Griffiths
85 110, 92 110, 92 RR, 06 LR3
I have a rear axle housing from a 92 Range Rover- hub to hub including calipers, rotors, and brake pipe.
Has a welded-on SG diff guard.
Easy swap to fit disc brakes to a drum brake 90!
Also have the 10 spline diff and half shafts/drive caps.
Complete front axle from same Rangie, diff, cv's, radius arms, panhard rod.
bolt on diff guard.
Front calipers from a Disco 1, fitted with a GBR spacer for using with vented rotors as fitted to ABS Rangies. These calipers are single pipe.
Make offer, trade for something?
Email is
Same place, new dogs.
Old April 11th, 2014, 05:32 PM
sedat
Sedat
97 D1 Se7
whatcha asking for the calipers?
Old April 11th, 2014, 08:10 PM
Roverlab
Trevor Griffiths
The fronts? How about $130 for the pair shipped?
Email is
axle, brake
Short side axle for disc brake sals Uncle Douglas Wanted 1 September 24th, 2012 06:51 AM
Brake/Friction Pad (and maybe Brake Disc/Rotor) Replacement rijosho Defender Technical Discussions 62 March 16th, 2011 03:55 PM
RHD Salisbury Disc Brake Front Axle Kit FS SafariHP The Vendors Loft 0 December 31st, 2010 08:05 AM
Salisbury Axle with a welded on stub axle, disc brakes, Factory? Capt Milks Defender Technical Discussions 5 December 21st, 2010 09:45 AM
Rear 24 Spline Axle Shafts $100/pair Wolf Fabrication For Sale - Parts 2 August 17th, 2010 07:36 PM
