Defender Tune Resistors - Defender Source
Old April 24th, 2016, 07:31 PM
CapeRoverKid
Brandon
none
I have 4 3.9v8 Defender or Range Rover Classic Tune Resistors.
asking $50.00 each
Old April 26th, 2016, 09:09 AM
CapeRoverKid
Brandon
none
Originally Posted by CapeRoverKid View Post
I have 4 3.9v8 Defender or Range Rover Classic Tune Resistors. asking $50.00 each
pictures added
ID:	148119   Click image for larger version
Old April 26th, 2016, 09:28 AM
cellulararrest's Avatar
cellulararrest
Chris Snyder
1994 D90 #614 | '07 L322 SC
Just FYI, these are resistors for the speed sensing circuit. Not tune resistors. They should be 6.8kΩ
Old April 26th, 2016, 09:42 AM
Technically it's a current limiting resistor that links the 9v coil output to the ECU ... this signals to the ECU that the engine is running and turns on the fuel pump.
Ask Josh how we know this in excruciating detail ....
Old April 26th, 2016, 09:45 AM
cellulararrest
Chris Snyder
You coulda just read this Rover 14CUX Hot Wire Mass Flow EFI: Service and Troubleshooting lol. Is Josh's truck finally "reliable" again? It wasn't at romp, was it?
Old April 26th, 2016, 09:50 AM
define reliable?
Old April 26th, 2016, 10:11 AM
Honda Civic
TUNE UP KIT&ALLOY LUGS WANTED 83 110 mountainviewrover Wanted 4 April 6th, 2008 12:44 PM
Re-tune ecu without catalytic converters Help! bstraw Defender Technical Discussions 0 December 23rd, 2006 10:48 AM
tune resistors and cats vesparover Defender Technical Discussions 3 March 13th, 2006 10:34 PM
"tune resistors" boxerhips Defender Technical Discussions 3 January 17th, 2006 07:10 AM
NAS spec D90 tune resistor help required UKlandyandy Defender Technical Discussions 8 May 7th, 2005 07:05 AM
