Defender TD5 performance Remapped ECU and 10AS - Defender Source
Old February 5th, 2013, 05:06 PM
Ben01
Ben
Defender
Defender TD5 Remapped ECU and synced 10AS
This was probably the best map I have used. Great low end speed.
After about 6 months I had an issue with either the 10as or the ECU. The 10as has a bad relay, but I honestly don't know the source of the main problem.
I was having an issue starting and it was easiest for me to just replace the entire setup. Someone who is good with electronics could likely fix the problem.
The ECU was chipped and remapped. The horse power is about 165. This is not the map for fuel economy and is more for speed.
This was done by a shop in England and was not an ebay purchase; unfortunately I paid about $1000.
It has been sitting for quite some time. Best offer takes the setup.
I can ship it in a flat rate box so it shouldn't be too pricey to ship.
Ben
ID:	65793   Click image for larger version
ID:	65795   Click image for larger version
Old February 5th, 2013, 05:08 PM
tjfslaughter's Avatar
tjfslaughter
thomas
Burbon
Did you install the boost box?
Old February 5th, 2013, 05:10 PM
Ben01
Ben
Defender
Correction, I have the boost box. Let me see if I can edit it. I'm going to keep it.
defender, ecu, td5
Defender TD5 TDCI 10as Alarm ECU YWC106270 Ben01 For Sale - Parts 9 March 22nd, 2013 06:45 PM
