Defender rear door, puma lock - Defender Source
Old September 18th, 2016, 04:58 PM
Ben01
Ben
Defender
$200 picked up in Manhattan. Please pm me if you are interested.
Rear door off of a later 90s-early 2000s Defender in Epsom green. The exact year is unknown, but I do know Epsom was the original color. We can narrow down the year to between 98 and 2001.
Good points:
The door has been set up to take a td5-tdci rear lock (included) and it has an aftermarket power door lock actuator. The power door lock function was working when the door was removed. The actuators are very inexpensive if for some reason it needs to be replaced down the line. The lock does not have a key. I can recommend a locksmith downtown who will cut a key for $40 if you bring the lock over to him.
The door is pre-wired for a third brake light and rear defroster.
The wiper motor is genuine. I tested it about two-three years ago and it was working.
I added a metal plate and tabs to take the puma door card and door grab handle without any major mods.
Bad:
With the spare tire mounted to the door, it rattles. Without the spare mounted to the door, it is fine. This can likely be fixed by reinforcing it somehow as I am sure it has broken down over age. An easier fix would be to use a swing away spare carrier.
There are a few minor dings here and there---visible in photos.
It was somehow taking in water and dripping rust, which is why it was removed. It wasn't horrible, but I don't drive the truck much so it was amplified.
The glass should be replaced and needs new trim (in my opinion). Potentially it can be cleaned, but it has silicone and paint overspray on it.
ID:	157889   Click image for larger version
ID:	157891   Click image for larger version
ID:	157893   Click image for larger version
Old September 19th, 2016, 01:49 PM
Ben01
Ben
Defender
If you are local and want to check it out, that is fine. There is one person who has first dibs pending inspection.
Ben
Old September 21st, 2016, 10:16 AM
ShoreRover's Avatar
ShoreRover
Brandon Sherwood
'91 110 5dr
Rear Door
Ben if your first prospect doesn't work out let me know, I may have interest and can run up and take a look.
Old September 25th, 2016, 09:14 AM
Ken10017
Ken R
D90 RHD V8
Ben
I'll have it check out this week.
thanks
Old September 25th, 2016, 09:40 AM
Ben01
Ben
Defender
Ok thanks
Old October 10th, 2016, 03:57 PM
Ben01
Ben
Defender
sold
defender, door, puma, rear door
Puma rear door and new rear sliding windows Ben01 Wanted 1 March 6th, 2016 07:02 PM
Defender 90 300tdi HARDTOP /COUNTY CONVERSION with PUMA BONNET - FUJI WHITE /PUMA FROMUK For Sale - Vehicles 17 December 9th, 2015 03:54 PM
Rear door card for Td5/Puma door Talleyrand Wanted 1 February 6th, 2014 10:08 AM
Puma Door Lock Barrels ersatzknarf Wanted 5 January 24th, 2014 10:58 AM
Pressed doors ( TD5 / Puma ) lock barrel? leastonce Defender Technical Discussions 3 February 8th, 2013 01:27 PM
