Defender rear door lock latch assembly FQJ500340 - Defender Source
Old July 5th, 2013, 12:21 AM
Ben01
Ben
Defender
Defender Rear door lock latch assembly FQJ500340
Fits models without central locking. This fits all Defender. It works perfectly.
I added central lock to the back door and replaced it with the appropriate lock instead of butchering this one.
I am including the lock barrel and keys.
The part that shows corrosion goes behind the seal plate and is not visible.
This lock has a 2005 manufacture date.
You may want to get a new lock barrel as they are very inexpensive.
$45.00 shipped.
ID:	75409   Click image for larger version
Old July 5th, 2013, 08:39 AM
please do a write up on adding central lock. I plan to do that at some point in near future, and it's not well covered on the net.
Mark Kellgren
KM4BOR
Old July 5th, 2013, 08:43 AM
jcb-memphis's Avatar
jcb-memphis
Jeff B.
PM sent
LR History:
110 hybrid (from a 90) NAS Defender "Oates" #1597
2002 D2 SE "Very Disco" (sold)
1993 RRC LWB "The Beast" (sold)
Old July 5th, 2013, 11:42 AM
Ben01
Ben
Defender
Buy the compatible remote central locking rear lock. Not a tricky job. The other door locks do not need to be altered. Feel free to pm me. I had found some write ups from the Brits but they required destroying the lock I have listed.
Old July 5th, 2013, 12:00 PM
Ben01
Ben
Defender
Originally Posted by jcb-memphis View Post
PM sent
I just responded, your's if you want it.
To clarify, this is the TD5 door lock but it fits the 200tdi-300tdi door as well. Fits all defenders 1987-present.
Corrosion nothing, the seal plate goes over it and I haven't tried cleaning it. You will need the below parts if you can't reuse them from your lock.
FRN500020 - Seal
EKC000030PMA (black plastic thing that goes around the lock barrel).
Part number for the lock barrel if you want to replace it: 395141.
Old July 5th, 2013, 01:55 PM
jcb-memphis
Jeff B.
FRN500020 - Seal
Check your email and PM.
Thank you - yes, I'll take it.
LR History:
assembly, defender, door
Rear end rotting out Defender 90 WOVOKA Defender Technical Discussions 6 May 13th, 2011 11:22 PM
Rear Ladder LenB Smaller Projects 16 July 15th, 2007 01:10 PM
1995 Yellow Defender 81k Miles for Under $24k gamberik For Sale - Vehicles 9 December 3rd, 2005 09:47 AM
Garage Sale: Disco And Defender Stuff ember For Sale - Parts 5 October 4th, 2005 12:24 PM
Rear door inner panel Kimos Defender Technical Discussions 4 October 15th, 2004 12:57 PM
