Defender R380 transmission for 300tdi (or 200tdi) - Defender Source
Old November 23rd, 2017, 06:15 PM
Macker's Avatar
Macker
Mack Crouch
1988 110 LS 5.3
For sale is a used defender style r380 5 speed transmission for 300tdi. Will also fit a 200tdi (that’s what I had it behind) but the bellhousing for 300tdi style is longer, and would put the 200tdi farther forward. I bought this as a new/rebuilt unit from AW Transmissions UK about 4 years ago and put approximately 20k miles on it in my defender 90. There is one issue- the rear of the transmission case lower corner has a small chunk that cracked off at the bolt hole, and the bolt can still be installed but only about half the hole is there. This was my error during install and has had not caused me any issues. You can sort of see it in the picture of the output shaft and I can post a better one. The transmission shifts flawlessly and does not leak (although it’s a little greasy from my old very leaky 200tdi). There is a small amount of deformation to the output shaft from running a non cross drilled input on my LT230, however it’s still engages without issues. I’ve had this stored in my shed but I realized I don’t think I’m ever going to be running a Rover diesel again. Happy to strap it to a pallet and drop it off at fastenal, or I can meet a buyer within a reasonable distance from Carmel/Monterey CA.
Asking $750.
Macker's Avatar
Macker
Mack Crouch
1988 110 LS 5.3
Front
Old November 23rd, 2017, 06:17 PM
Macker's Avatar
Macker
Mack Crouch
1988 110 LS 5.3
Output shaft
Old November 24th, 2017, 08:53 AM
is this a Discovery R380?
Old November 24th, 2017, 09:42 AM
No, it is Defender (long stick).
Old February 12th, 2018, 01:10 AM
Macker's Avatar
Macker
Mack Crouch
1988 110 LS 5.3
Bump $500
200tdi, 300tdi, defender, r380, tdi, transmission
LHD Defender 110 HiCap 200Tdi - 10,424 original miles vtlandrover For Sale - Vehicles 14 November 3rd, 2017 09:07 PM
1991 Defender 110 5 Door CSW 200tdi mech For Sale - Vehicles 16 October 5th, 2017 08:29 PM
Defender 90, 200tdi 1991 Macer77 For Sale - Vehicles 5 July 11th, 2017 03:56 PM
Looking for a R380 Defender Shifter rdavisinva Wanted 0 February 16th, 2013 11:06 AM
Defender Transmission Mechanic NJ/NY area WOVOKA Defender Technical Discussions 7 September 14th, 2011 04:08 PM
