Defender 90 NAS ROLL CAGE B Pillar and Parts - Page 2 - Defender Source
Old April 5th, 2016, 01:50 PM
defenderholty's Avatar
defenderholty
Russell
1985 LR Ninety 200tdi
Thanks for the info. Mind if I pm you a question or two?
Old August 11th, 2016, 10:08 AM
defenderholty
Russell
They were badly split when I got this thing. The rubber is in shit shape, but I kind of figured that from the pictures.
So I am finally in the phase of my project to start thinking about mounting this thing. Its effin bent. I guess it was rolled at some point. Any ideas on how to straighten it?
My bad on the sideways picture. My computer keeps uploading them wonky.
Old August 11th, 2016, 10:20 AM
defenderholty
Russell
I guess I should think about starting a thread somewhere else
Old August 11th, 2016, 10:35 AM
I would bolt on one side and then rachet strap the other side (the side that was bent) into place slightly over correcting before bolting it down. I bet it fits fine in the end.
Old August 11th, 2016, 10:50 AM
Well you can't say you weren't warned. All of the trucks he's represented have been salvaged and or wrecked and I wouldn't have expected much more from these parts. That said, hopefully you can bend them back into place, and the foam can hold up a few more years for you.
You could sort of see from the second pic in the original pics that the driver's side B pillar foot appeared to be out of whack a bit.
Old August 11th, 2016, 10:58 AM
defenderholty
Russell
I was warned, but the transaction had already taken place. I'm ok with the foot being a little bent, I can press it back and I can repair the rubber, but I need to move the right side back inward around 2 inches, and hope I can do that and still line up the a hoop.
------ Follow up post added August 11th, 2016 11:03 AM ------
Thanks for the input.
I put a ratchet strap on it the other day and probably had 500lbs of pressure on it which pulled it in a little, not quite far enough. I think if I pulled it in and bolted it down it might distort my tub. Maybe with the w bar in place it will hold it all together.
Old August 11th, 2016, 11:12 AM
Originally Posted by defenderwrecker View Post
Rubber is solid with no missing pieces,
See if Creed will honor his own word and give you some sort of credit for the clearly misleading description he provided you. You may also check with a body shop to see if they can straighten it, or reach out to user lobster here since he'd rolled his truck pretty good down a hill and was able to have the cage brought back to better than I'd expected.
Old August 11th, 2016, 12:14 PM
That is why you need to over pull it. Come along or winch rope etc if the strap won't do it.
Old August 11th, 2016, 01:13 PM
defenderholty
Russell
Gocha. Thanks
rovertrader's Avatar
rovertrader
Dale
THIS I gotta see!!!
Old January 20th, 2017, 02:42 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Originally Posted by rovertrader View Post
THIS I gotta see!!!
Did the leopard change his spots?
RDavisinVA
Old January 21st, 2017, 07:21 PM
Shane@EVS
Roverhybrids
I've had some luck bending one back by inserting a ~6' long heavier wall tube and rigging up something to hold the cage piece while I pulled the lever
Old January 22nd, 2017, 08:17 PM
defenderholty
Russell
I'll give it a go. The build has been at a crawl. Ashley and I have a new addition that is taking up most of my time. I am getting close. I hope to have it all together to make Uwhahrrie.
90, cage, defender, defender 90, nas, part, parts
NAS ST A-B Pillar Horizontal Roll Cage Bars Method PHX For Sale - Parts 3 July 30th, 2014 12:36 PM
ST b-pillar c-pillar and cantrails dave_lucas Wanted 7 May 12th, 2010 11:39 AM
A Pillar Cage and B pillar seat belt holders CDeWan For Sale - Parts 14 December 24th, 2009 07:18 PM
roll cage a pillar wing mounts rgrrvr Wanted 10 January 24th, 2008 10:19 AM
