Davis Unified Ignition - Defender Source
Old August 2nd, 2013, 07:55 PM
RoverLover5023
Alejandro
1965 Series 2a
DUI for sale for a 3.9 rover engine. came out of a nice rig that was parted out..I knew the owner and saw the d1 perform..Is in working condition with wires..looking to get half of what they are new..
ID:	76855   Click image for larger version
Old August 2nd, 2013, 08:05 PM
CDeWan
Clay DeWan
5.3L beastie
Davis
How does this differ from a Unilite? Thank you in advance.
Old August 2nd, 2013, 08:37 PM
RoverLover5023
Alejandro
1965 Series 2a
Not sure about the unlite, but here is some info of the dui for a rover.
Until now, performance ignition manufacturers have almost totally ignored the performance needs*of Land Rover and Range Rover owners. For these vehicles we have addressed the issue of a*weak spark by offering a DUI! No, this is not the DUI you most commonly hear about. We are*referring to a Davis Unified Ignition, which is a high performance distributor designed to improve*fuel mileage, horsepower and torque! The DUI is a complete ignition system in one simple unit.*The compact design makes this unit virtually water, mud and vibration proof as all of the electronic*components are located inside the distributor. No external coils or spark boxes are needed! The*DUI features a 50,000 volt coil that allows spark plug gaps to be opened up to .055". Our high*dwell Dyna-Module makes the coil produce a longer duration spark over a stock module. The*combination of the two provide the most complete combustion of the fuel mixture possible for a*difference in power you can feel! In addition to the hotter spark, the mechanical and vacuum*advance is tuned for optimum performance. Using information about the vehicle and engine, we*can tune an advance curve that will provide instant throttle response and more power throughout*the rpm range without any pre-detonation. We do this using a Sun distributor machine and dialing*in the proper weight and spring assembly. A non-adjustable vacuum advance is then selected to*compliment the mechanical advance. This type of custom tuning is a service you will not find with*any other ignition company! The DUI is built for durability and features both upper and lower oil*impregnated bronze bushings. Dual bushings provide shaft stability for accurate trigger signals*and years of trouble free operation. The DUI Distributor is unsurpassed in quality and each unit is*hand built to exact tolerances. If your Rover could benefit from quicker starting, smoother idle,*more horsepower and better gas mileage then itís time to start Driving Under the Influence of the*Davis Unified Ignition!
Old August 2nd, 2013, 08:43 PM
I'm interested but need to know a price ? (required by the forum rules)
If you are asking $150 plus shipping, and thats a complete set of plug wires that will work with that cap, I'll take it.
Old August 2nd, 2013, 10:21 PM
RoverLover5023
Alejandro
1965 Series 2a
I was hoping to get somewhere around $300?? Is that fair? These units are $655.00 for the fuel injected. .im also comes with the plug wires..thxs
Old August 3rd, 2013, 12:40 AM
http://www.summitracing.com/parts/du...ake/land-rover
if you change your mind, I'm a buyer @ 150 with the leads.
Old August 4th, 2013, 12:55 PM
RoverLover5023
Alejandro
1965 Series 2a
Bump 250ish??? Anyone. .
Old August 4th, 2013, 07:33 PM
cellulararrest's Avatar
cellulararrest
Chris Snyder
1994 D90 #614 | '07 L322 SC
Would you take $200 w/ the wires?
Old August 4th, 2013, 10:31 PM
RoverLover5023
Alejandro
1965 Series 2a
Pm sent.
Removing Faulty Ignition Switch - It's STUCK rijosho Defender Technical Discussions 20 March 29th, 2017 12:54 PM
Davis Unified Ignition spartan Defender Technical Discussions 4 December 13th, 2011 09:33 PM
Ignition? Trigger Defender Technical Discussions 12 August 1st, 2005 08:53 PM
different ignition options vesparover Defender Technical Discussions 5 December 5th, 2003 03:02 PM
